Question about AEG 23 in. Favorit 88070IM Built-in Dishwasher
Antiflood system triggered-how to reset on aeg favorit 35080vi
No possible apparent reason 3 short warning tones and buzzing
  • defflugs Apr 20, 2009
    Anti Flood warning with 3 beeps comes on now after I opened the door mid cycle by mistake
    Is there a reset option as the machine is not leaking
    Thanks
  • robinkrogh
    robinkrogh Aug 15, 2012
    got the same problem. flood area is dry and the sensor is not triggered
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Posted on Jan 12, 2010
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
What is the most usual reason for leakge on the AEG 6050?
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified..
Jan 16, 2010 | AEG 24 in. Favorit 60830 Free-standing...
Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Warning lights flashing for Anti flood system triggered and dishwasher not operational
The bottom "Y" 3 point hose at the bottom connected to main motor is of poor quality and does have 3 wire clamps. The hose does perforate and small pin hole causes water at the bottom to trigger the anti flood system with warning lights flashing and pump motor on ...
Dec 21, 2009 | AEG 24 in. Favorit 40660i Built-in...
AEG Favorit 6040 Dishwasher has continuous tone (from Pump?) even when switched off at the power button. It cannot be set to any programme.It overflowed some froth when put on a recent cleaning 'phantom...
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Nov 11, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
Oct 02, 2008 | Dishwashers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Drain pump
Switch off at the mains. Take a side panel off and tip your dishwater over 45degrees towards th open side. Make sure you put towels down to soak up the water that will come out of the base. This will reset the flood detector. Reassemble. Switch back on and let the dishwasher finish its cycle and away you go. Remember this does not solve the reason for the flooding but it will get your dishwasher going again. Depending on the cause of flooding you may only need to reset like this once a year.
Jan 21, 2008 | AEG 24 in. Favorit 40260i Built-in...
Favorit 44070Vi 3 short warning tones
It is most likely to be the wash pump leaking underneath, the float switch lies underneath the dishwasher, if you tip it back slightly you will probably find that water will leak out, that will prove that it is leaking and it will probably work a couple of times after this but it isn't the answer i'm afraid, a wash pump is not really the sort of thing you should tackle yourself.
Nov 26, 2007 | AEG 23 in. Favorit 44070Vi Built-in...
AEG 23 in. Favorit 88070IM Built-in Dishwasher Logo
3,033 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
