Question about Pioneer 1000 Watt 5.1 Surround Sound System System
Sounds comes onbut for only a sec and goess off
The sound comes on first and then after a couple seconds goes off.Its a pioneer surround sound 5:1 . turn the system off and onn again the sound comes back but goes off after a couple seconds again.
  • 3 more comments
  • kenrowsell Feb 08, 2009
    hi yes they are it was working fine before
    The
    The system is about 10yrs old. model number is xv-dv55
  • Scott Frye
    Scott Frye May 11, 2010
    It sounds like there's a failed output section hence the protect mode.
    Parts are available for that unit still.
    How old is it?
  • Scott Frye
    Hi...
    Are ALL the speakers connected at both ends and connected into the right places?
    THanks
Pioneer Model SDV77 Turns Of immediately Indicates DVD 5.1 CH Error DVD 3.3 Error
Posted on Feb 19, 2010
LG dlg0332W gas lights up for 4 seconds and goes out for 5 minutes and repeats
It sounds like a plugged or restricted exhaust vent or blower wheel might not b spinning, check blower and belt:)
Nov 30, 2013 | Dryers
Surround sound cuts out
puhs can try cleaning the button with wd-40 l of effect changes on the front panel card also control system may have excess dirt.
Sep 07, 2013 | Harman Kardon Audio Players & Recorders
I have dell inspiron 1100 laptop, when i turn it on fan goes on for about 15 sec,with no screen, power lights and battery lights either, i can hear sound from HDD and DVD rom, but after 25 sec everything...
Could be loose battery pack.
A bad memory chip would do this as well. Sounds like your not getting power.
Try this,
Unplug it, remove battery, wait couple minutes, press and hold the power button for 5 full long seconds, wait couple minutes more, then put battery back in securely, then plug in, turn back on.
Mar 07, 2010 | Dell Inspiron 1100 Notebook
Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Feb 08, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a pioneer 5.1 channel surround sound system and it powers up and everything seems to go fine but you go to turn it up and no sound comes out of the speakers already checked speaker wire connections...
Does the protection relay click 3 to 5 seconds after initial power on??? If not, your unit is staying in "protect" mode to save your speakers because the output transistors or output IC is shorted and sending 40 to 60 volts at your speakers. Not a good thing, but at least it saves your speakers.
Good Luck!
barneyluc
Oct 03, 2008 | Pioneer Audio Players & Recorders
Sub won't stay powered up
well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
Aug 09, 2008 | JVC TH-C30 System
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
I have a jvc 1200 stero
As a general rule surround sound is only sent on HD signals for the dvd. Otherwise it comes to your home in basic stereo sound. Consult your user manual for ways to turn on simulated surround sound also known as Dolby ProLogic.
Mar 03, 2008 | Pioneer HTD-510 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
Pioneer 1000 Watt 5.1 Surround Sound System System Logo
279 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
