Question about Dell Computers & Internet
Error message C:Documents and Settings adinebinnsApplicationDataMySpaceIMSkypeCacheshared.xml is corrupt and unreadable. Please run the Chkdsk utility. What do I do? Thanks
  • 73 Answers
If you click on the start button and then select run, you can type in cmd. This will bring up a black window and inside of that you can type chkdsk /f . You will then need to follow the prompts on the screen and it may have you restart. When it does restart it will run a program to check for errors on your hard drive. If it finds errors it will repair them and you skype should be fixed.
If this does not fix Skype please uninstall and reinstall.
Posted on Feb 08, 2009
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
Dec 05, 2013 | Rosetta Stone V3 Spanish (Latin America)...
Error 9119 rosseta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Error 9119, 9114 rosetta stone
Dec 29, 2012 | Rosetta Stone Computers & Internet
We have windows xp and right now when we boot up the computer this window pops up saying google update.exe-corrupt file(window)then below it THE file or directory c;\windows\temp\gur3.tmp is corrupt and...
You need to run CHKDSK from a command prompt window.
Open the start menu and click 'run.' In the text box, type 'CMD
In the command prompt window type CHKDSK /r and press enter. It will ask if you want to run at next start up enter y and press enter.
PLEASE NOTE there is a space between the K and //.
Reboot PC and CHKDSK will run and fix the error.
Dec 12, 2010 | Dell Dimension 2400 PC Desktop
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Computers & Internet Logo
21 people viewed this question
Alun Cox
