Question about Fujitsu Siemens AMILO Pro V2000 Notebook
LCD Screen barely visible on Amilo Notebook 7300
My LCD screen suddenly would not light up. I can just about see something and it's making all the right noises but no picture. I have tried to increase light but I don't think that's the problem. You can hardly see the cursor so it makes it impossible to navigate.It's as if a light has gone out. I can see nothing in the manual about this problem.Can anyone help?
  • miketheodoro Feb 08, 2009
    Many thanks
    Would it be possible and safe to connect the laptop to another monitor so I can access some documents on the laptop. Would I be able to see anything on another monitor?
  • 63 Answers
Your back light has gone out and will need to be replaced by a qualified technician
Posted on Feb 08, 2009
  • Kim Tyler Feb 09, 2009
    yes, you should be able to use a regular monitor
Fujitsu amilo Si3655 laptop screen coming blank
It Sounds Like The Problem Is Caused By Settings For A
Screen Saver You Have Enabled! If This Is Correct Then
All That Is Needed Is To Ajust The Settings Or Disable It
Completely! See The Manual For Both The Laptop And The OS For Further Details!
Apr 02, 2014 | Fujitsu Siemens Amilo Si 3655 13.3" Laptop...
Thanks. Compaq Presario F761 US: When I hit the power button, it comes on for a split second. That's it. Help.........
I'll give you something to try :
using a bright light florescent ,lcd, etc. shine it right on the screen. Look in the center of the screen for the windows logo (might be barely visible).
If this is the case, you either have a bad inverter or the CCFL in your lcd panel is bad. If it is, re-post and we can walk you through troubleshooting or replacement.
Aug 31, 2011 | HP Compaq Presario F761US Notebook PC
The laptop screen has turned bad. Color changed. the screen has a split at the bottom. Rest of the thing is ok. I can work on the computer and make out the content ofthe screen.
Make sure the LCD is not cracked. Sometimes these cracks may not be visible to the bare eye. have you stepped on it, put something on it or anything similar?
Just in case it is your LCD, see if your warranty covers it, if not you are better off buying a new laptop. One of my friends paid $500 on an Acer, he stepped on it, warranty wouldn't cover it and he was asked to pay $400 to have it fixed.
If this is a software problem, I can't think of anything else but the Screen properties, like Colors, or resolution.I can only think this is a hardware problem.
Jul 31, 2010 | HP Compaq nc6400 Notebook
My screen is extremely dark. barely visible. external monitor works ok.
You probably have a bad LCD panel back-light. Time for the repair shop. Probably not worth repair though. Unless you have warranty or extended warranty.
Could also be an inverter board ... which supplies the high voltage for the back-light.
Nov 22, 2009 | Compaq Presario M2000 Notebook
The screen on my laptop went dark, i can still see some things but just barely, it's as if the LED light burend out or something. How might i fix it? can anyone offer a repair estimate?
check first the inverter because sometime cause fo darknes of screen is the inverter not working.. or led light burend out..
first thing to do is check the inverter..about the cous of estimante.. $ 30
Sep 13, 2009 | Fujitsu AMILO D-8820 Notebook
Screen is very dim..can barely see it..bright adjust doesnt help.
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
May 17, 2009 | IBM ThinkPad T20 2647 Notebook
Screen is dark and barely visible
the lcd back light is dead
replace lcd
sorry hardware fix :(
Apr 10, 2009 | Acer Aspire 5610-4648 Notebook
Amilo pro v2030
You need to pull off the part right along the top of the base of the laptop (where the lights show for power, Caps lock etc.). Pull that off and then take the clip off that goes over the bottom part of the screen. Lift the screen and there you hve the screws visible to remove.
Gerry Brannigan
www.fix-my-computer.co.uk
Nov 08, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
242 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
