Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Open with window opens when double clicking a drive
Whenever I double click on a drive the small window called "OPEN WITH" opens. and there are no contents to be found in the drive whenver i open it with other applications. what should i do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Dear sir
please install mcafee antivirus & sacan the entire system.
it will recover ur lost files
regards
murali
Posted on Feb 08, 2009
Changing how to open drives
2 things...go into ur Control panel and in the MOUSE area change the way ur mouse clicks to run things..then save those settings.
OPen Real Player options or preferences. Look for an option to how it handles running things. then uncheck it. save those settings.
May 24, 2009 | Microsoft Windows XP Home Edition
Tip
Drive not open on 'double-click'
Open 'Notepad' and write following code.
[autorun]
open=C:\Windows\explorer.exe
Save file as 'autorun.inf'.
Copy/replace this file on all drives/partitions that are not opening on double-click.
Restart PC and now all drives should open with normal double-click.
on Aug 26, 2010 | Computers & Internet
Tip
Drive can,t open on double-click
hi there,
many times user face this type of problem.
first ,of all open -my computer > open tools tab > then folder option >then view tab click on "show hidden files"and uncheck "hide protected oprating system files" then ok
second , click on folder button (standred button) "it is up to address bar or next to search button"
now click on drive in left side explorer window now you can see folders in drive "delete" autorun.inf file in drive.
third, go in drive properties by right click on drive in explorer window,
click on "tools" tab click on "check now"
mark on automatically fix file system error and click start
it will start checking file system and fix it or it will ask fix it on next restart (it checkdsk command in windows gui mode )
after restart chkdsk start and your drive will again open on double-click.
on Jan 27, 2010 | Computers & Internet
Auto Play
* Click Start
* Click Run
* Enter GPEDIT.MSC
Group Policy mmc will popup. On left panel:
* Double-click Computer Configuration to open submenu
* Double-click Administrative Templates to open submenu
* Double-click System to open submenu
* Double-click Turn autoplay off option which will be near the bottom of the list in the right panel.
The default is the Not configured. Set it to Enabled."
May 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
HKEY_CLASSES_ROOT\Directory\shell
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
Problem while opening hard disk drive.
unable to open my computer drives like C, D.whenever i double click the drive it show open with some programmes.I bought three month before.Begining it open when i double click but now it is not possible
Aug 14, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Unable to open documents with double-click?
Restart your computer and see if it corrects the problem. The other thing you gotta watch out for is if you have word 2007 documents on your server. Those won't open in 2002 because the file extensions are different. You need to download the converter program from Microsoft to use them.
You should update all you Office 2002 software as well to SP3.
Aug 04, 2008 | Microsoft Word 2002 for PC
Opening of drives
I have seen this several times and it is brought about due to a virus that creates an autorun file (autorun.ini).
In this file when you double click the drive, executes the file and in the autorun file exists any of the following: -
Microsoftpowerpoint.exe
smss.exe
.... or many others.
It is good thing that you have a strong antivirus which seems to have removed the viruses and therefore when the information file is opened, it does not find the executables it was supposed to run. That is why it asks for a program to open.
You can prove this by right clicking on the drive to see a shortcut menu and in this menu, the bolded menu will be the action taken when double clicked and the possibility is that you will find Autorun bolded.
To resolve the issue do the following:
1) Open My computer program or windows explorer.
2) Right click on the drive and open or explore it.
3) Locate the file Autorun and delete it. If the file is not shown, from the folder options choose show all files. This is because sometimes this file may be hidden.
Try double clicking the drives again to see if you get he same error.
NOTE: Many virus developers have made possible for people to install/run viruses in there own computers by simply double clicking the drives like flash disk.
May 31, 2008 | Microsoft Windows XP Professional With...
Open drive
select folder view and tick "always use this"
if you double click on your hard drive,it should open in explorer view anyway.
good luck
Terry
Mar 10, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
