Question about Samsung WF337AA Front Load Washer
Samsung washing machine B1215J E6 error what is this
E6 error
  • 2 more comments
  • Anonymous Feb 13, 2009
    I have the same problem. As soon as the washer starts spinning, the machine violently moves and stops with E6 on display. What is the reason for this error and how it can be fixed?
  • eagleflyt Feb 23, 2009
    I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced.
  • jucomo01 Mar 06, 2009
  • Anonymous Mar 15, 2014
    The machine gave an E6 error so I leveled the machine and replace the water filter to the machine. The E6 is sorted but getting a E13 error
Posted on Mar 06, 2009
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
Lg top load washer e6
Oct 21, 2012 | LG WFT1071TP Top Load Washer
I have a samsung sensor quick P801 800 front loading washing machine. It is giving me error code E6. Is this an easy fix?
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Sep 14, 2010 | Samsung Washing Machines
Samsung b1215j code e2 lights up. any clues,
Lo M8
E2 code means it's not draining out the water properly
so look for a blockage at the pump
turn the power off to the machine
take the front bottom plastic cover off so you can access
the drain tube front right small plastic plug bout 13mm in size
get some towels and a shallow tray to catch the water
remove the small plug and drain the water ( takes age by the way )
once you've done that put the small plug back in
and then unscrew the black plastic ( they come in several colours )
pump access plug bout 50mm in size which is just to the left
of the drain tube ,, there may be a small amount of water left
in the pump but it won't be much
Once the pump access plug is removed look inside the hole
and see if you can see anything stuck in there most often
it's coins or other junk thats been left in pockets or very often
if you've kids it's going to be socks or other small clothing items
which have been sucked in to the pump
remove any blockages refit the pucp access plug
turn on the machine and put it thru a quick wash cycle
make sure it drains and spins out !!!! if not then repeat the above
procedure as you've got something else still stuck in there
good luck
Spiidi
Dec 16, 2009 | Samsung Washing Machines
Samsung P801DWNXRC Frontload washer displays E6 error code
Apr 28, 2009 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
1,776 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
