Question about LG Vacuums
LG V-CC162HTU my cyclonic wont **** :-(
It is brand new and the suction is really low. I have cleaned the filter etc.
  • 276 Answers
Sometimes with a cyclonic vacuum it takes a while for all the fine dirt to be sucked out of your carpet. Sadly it could be a case of persisting until all of the fine dirt has been collected. If you have access to a compressor or air gun you can use that to gently blow out the dirt from the filter. Also make sure there's no blockage in your hose.
Posted on Feb 24, 2009
Very low suction. hardly picking up dirt . cleaned rollers and all openings.
There could be an obstruction somewhere. Start from the brush bar and work your way back trying to determine where it is.
Mar 14, 2015 | Dyson Dc18 "slim" Upright Model...
I have a Dyson DC07 and it has lost suction. I have checked the belt, cleaned the circular filter and emptied the dirt chamber. The hose still has plenty of suction but I can't use the hose the vacuum...
Here are some things you can check.First you need to see if the problem is with the suction or agitation.If the suction on the hose for using the attachments is low you either need new filters a new cyclone(they are not cleanable) or it is clogged.To check for a clogg remove the cyclone and turn on the vacuum cleaner.you can put your hand over the suction side of the handle tub and feel if it has suction there.Reinstall the cyclone and again check the hose.If it is the same you don't likley have a suction problem you have an agitation problem.The 2 belts on the DC07 are part of the clutch and when they are strectched to a certain point (3-5years) the clutch needs to be replaced.you can check the clutch by turning on the vacuum cleaner and applying slight pressure downward on the front of the vacuum head.If the vacuum makes a loud ratcheting noise or you can stop the brush from turning the problem is most likely the clutch.One last thing is to make sure the bottom plate is on correctly I often see a misaligned bottom plate and the brush dosen't hit the carpet so it dosen't pick up.  www.sewvac.com
Jan 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Have cleaned filters but no ever replaced them... suction is rubish always have to use it without the head on... any ideas, is it just new filters are needed?
Well, I have used one of those vacuums before and its suction was sluggish, and it was brand new too. It might be clogged up where the suction is produced, see if that. If not you might just need new filters and also you should call customer support too. Hope this helps!?
Apr 09, 2010 | Dyson DC11 All Floors Bagless Canister...
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Noisey DC07 Bagless Upright Cyclonic Vacuum; lack of suction...
Hi there it's SmartAlec from NelsonVacuums.com.au here. It is very likely you have a problem in the radix assembly or the filter is actually worn out. Basically to test either simply remove one then turn it on to test. If it runs better with out the filter (washable is most likely culprit) simply purchase a new one. If it is the radix assembly that is the problem it is possible to clean inside the little tubes by taking off the top and literally clearing dirt and fluff out with the help of a coat hanger. Alternatively a new one can be purchased. If you are in Australia or New Zealand I can help you with either part. Just put in a request via the email link n our website. Hope this helps regards Alec
Oct 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC7 full Kit, with one belt does not get suction to head.
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
Mar 21, 2009 | Dyson DC07 All Floors Bagless Upright...
Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Jan 15, 2009 | Dirt Devil M110000 Bagless Upright...
Vacuums Logo
311 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
