Question about Envision 19" Widescreen Flat Panel LCD Monitor
Cooked motherboard HELP: I have an hp slimline 3200n series and an Envision 19in LCD monitor. I believe I have a cooked motherboard (second one). My computer began locking up before finally not working at all. No fault/error codes,nothing, it died that fast. I did some online troubleshooting and narrowed the problem down to the motherboard. I replaced the motherboard and it worked fine, for a few days... The exact same problem reappeared. So,when I power up the computer,it begins to start but seems to hang up and will not completely start up. It is as if it is hung up in sleep mode. The monitor indicated "no signal". I called HP and explained. I was told that the monitor is the problem. Said that the monitor was drawing too much power from the motherboard and preventing it from operating correctly. I have unplugged the monitor but the computer still does not start up all the way (still hangs up on start-up). Have I cooked yet another motherboard? Do I replace the motherboard AND the monitor or turn the whole system into a boat anker? Please advise
  • 3,940 Answers
Personally, I've never seen a monitor damage a motherboard. Since monitors have their own power source, the HP answer of the monitor "drawing too much power" is bogus.
Possible failures could include the following:
  1. Failing Power Supply - if you haven't tried a different power source, then that is the 1st thing I'd look at, expecially if another system will run the monitor.
  2. A peripheral item, (Keyboard, Mouse, Printer, scanner or other USB device is preventing POST completion of boot completion.) try booting system with just video and power, nothing else.
  3. Check the monitor cable for bent/broken pins. I have seen bent pins on a cable connection short out a video card, this could cause a no post if the video is integrated.
  4. I just reviewed the HP site on this system, and it appears to ship with a PCI-E video card. It appears most likely that the Video Card (If one is installed). If you have the PCI-E video card in system, remove it, and connect to the intergrated video connection and see if ystem posts.
Posted on Feb 08, 2009
When i turn on my monitor (Envision G22LWk) it will go blank about 1 second after I turn it on. What might be the problem?
You may have power supply/inverter board problem due to bad caps, or worst case will be bad lamp assembly, the one shown here has broken lamps, you can hear arcing sound if you listen real close.
http://s807.photobucket.com/albums/yy352/budm/Envision%20G22LWK/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series
Apr 09, 2011 | Envision G22LWK 22" LCD Monitor
I work from home, have a company laptop and use the envision monitor for a second screen. It has an 'out of range' message in the middle of the screen. This happened a long time ago and somehow I was...
It is telling you taht the laptop video resolution feeding it is too high for it to display, you need to set it to the native resolution of this ENVISION monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Feb 02, 2011 | Envision 19" Widescreen Flat Panel TFT LCD...
Have HP slimline series. Came back from a break.
Try another monitor on it to verify it is the video card that has gone bad. If it does not work with another monitor then that is the likely culprit.
May 06, 2010 | Computers & Internet
Any chance of recovering an overheated motherboard . Unit not booting and suspect cooked mobo. Unit fires up, and stops after approx 4 seconds.
The MB is cooked its had it, but are you sure this is the issue, try it hooked to power with no battery installed to ensure it aint a crook battery steling the power..
Nov 07, 2009 | Acer Aspire 1690 Notebook
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Have a hewitt packard computer, want to add on envision monitor 7100s The system is not accepting monitor. what do I do?
To reinerate,do you have the driver for it? I am sure that  the old monitor was made by HP for your HP computer.
Go to the Envision website and download the LCD driver and install same.    Link provided below:
http://envisiondisplay.com/support.asp?EPage=support&SMenu=driver
Mar 23, 2009 | MPC Computers Envision EN 7100s 17 in....
Envision LCD monitor: ''Auto Config Please Wait'' is always on
Just tell me why this message comes up and if it means my monitor is going
Dec 21, 2008 | MPC Computers Envision EN 5100e 15" Flat...
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision 19" Widescreen Flat Panel LCD Monitor Logo
144 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
