Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Dyson 15 animal
Bottom has suction but the brush will not spinhas no suction when want to use in upright position have cleaned filter etc still no luck kindest regards louis
  • Louis 335 Feb 08, 2009
    when i take of the housing where the dust goes in it works roller brushing spinning suction great but when put back air shooting out the top of it this is a dc15 and this does'nt pick up kindest regards louis
    thank you very much two heads were better than one been on this problem all day now it goes better than it ever did kindest rehgards louis
  • Dyson Master
  • 19,396 Answers
Re: "when i take of the housing where the dust goes in it works roller brushing spinning suction great but when put back air shooting out the top of it".
That means that either the biun is not well assembled or it is cracked.
Replace teh filter first (see : here ).
Then check that the bin is assembled in the right way, and is well snapping when you mount it into the hoover.
If that does not help , then replace the bin assembly (see here).
here is an international seller: Govacuum
Here there is an UK part seller.vacuum cleaner parts,dyson replacement
Posted on Feb 08, 2009
  • 744 Answers
Hi.....It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area. ...
thank u..
  • 679 Answers
Check the seal of that unit. and let me know for further assistance.
Thanks
    Brigadier General:
  • 3,614 Answers
Better clean the unit.
check fore any loose connection.
check the belt, and the contact switch.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason for ur problem would be your
belt could have got damaged.It is better that
u replace your belt with a new one.
check it out..
thank u..
  • Hariharanath V Feb 08, 2009
    hi..the dust is going in and getting stucked
    in the blower itself.
    check it..
    thanks..
    President:
  • 2,110 Answers
You need a new belt and maybe a new brushbar.
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
My Dyson 14 Animal seems to not have the suction
Hi its Darran at Dyson.
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Apr 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal handheld brush not turning
We would recommend checking it for a blockage and a removing any hair or fibres from the brush bar.
As the brush bar relies on the suction power of your machine, it would be worth cleaning the filter and checking for blockages as this may cause a loss of suction will in turn stop the brush bar in the Mini Turbine head turning.
If you are still experiencing difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Liaison
Apr 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc17 animal will pick up via the hose attachment but there is no suction when you use the regular vaccuum on the floor - you can hear the difference in the suction once you put the floor part down...
Check that the brush control dial is in the centre position when upright and then moves forward when the head is released. If the brush bar is still not spinning when switched on in the vacuuming position, check the base for blockages and remove any threads or hairs from the brush bar as outlined in your user guide or on our website.
If you are still having difficulties, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Jan 16, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction not working
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 25, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson 15 animal
So I was having the same problem with no brush movement. Found this inductor exploded and wire melted off for the brush motor; However, this will allow the suction motor to work. I didn't smell it as much becaues the circuit board is inside the ducting before the filter. I have been looking for a replacement board but haven't found anything so tomorrow I will replace the bad parts on the board instead. Good luck to everyone else with this problem!2c752e0.jpg6da67b0.jpg
Jul 26, 2008 | Dyson DC15 Animal Bagless Upright Cyclonic...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
18 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
