Question about Maytag Washing Machines
Machine stalls no action timer continues
Our machine seems to stall and whilst the timer is saying how much time is left there is no action going on.  It is intermittent.  We canceled the cycle and managed to get it going again.  What could be the problems
  • cateneedshel Feb 09, 2009
    Thanks. I have looked at the filter and it seems OK but will check out how long it takes to pump out next wash. Cheers. Cate
    Problem Solver:
  • 16 Answers
It seems to me that you have something blocking your outlet pump.Many machines have a designated time to pump out water and if this time is to long machine will stop all action.Clean your pump and outlet hose If no help in this you can change to new pump.If this dont help post again and tell me when machine is stopping
Posted on Feb 08, 2009
Engine firing issue whilst driving and using left indicator (only) what could be the fault?
Have they checked for a short in the steering column where the signal switch and ignition wires may be touching or shorting together.
Jul 15, 2015 | Cars & Trucks
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
Maytag jetclean eq plus mdb9150awd Stalls at 68 min
Could be defective timer. The diagram might be on the back of the machine - out of sight, out of mind
Jul 24, 2013 | Dishwashers
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
Machine stops at drain and doesnt add fabric softener
When you say stops at drain(ing), do you mean just before, just after, or in the middle of ? And, does it pause and then continue but fails to add softener; just never advances to the final spin and end of cyccle ?
The problem could be in the timer control, or overload sensor (if so equiped). Sometimes the water levelsensor could do this. I assume that this happens every time. The first thing to do is to jump-out the wire connections to the timer that tell the motor to operate for spin/drain. if the machine works as it should, then you know the timer is at fault. If the machine still pauses or stalls, then you need to follow throught on the other control items. Goodluck, Macgivor
Jan 02, 2010 | Zanussi Washing Machines
We have a WGL 10 US model F&P washer. Most
Are you waiting long enough? Ours seemed to stall but eventually would start up again. Have you tried diagnostic mode? email me at Yahoo.
Sep 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Washing Machines Logo
49 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
