Question about Nintendo DS Lite Console
My ds water damaged????
I was playing ma ds in the bathroom..i went to put it on the sink rail..it shot off and went in to ma bath..so i go it owt asap .. n put in the airing cupboard upside downn....but it still doesnt work...i need to get 1 of those screwdrivers but i cant fynd 1...any1 got any solutions??
  • misoracto Feb 28, 2009
    Yes, me too.
    My brother's DS (lite) is broken.
    I'm searching how to repair DS Lite with Water damage.
  • mattycoxon Feb 28, 2009
    thanks sum people!!!!!!
Yea buy a new fuckin ds!!!!!!!!!!!!!!!!
Posted on Feb 09, 2009
Please, no bad laguage
Posted on Feb 19, 2009
What is the switch for by the bathroom sink
The hot water tank heater?
The pump in the well?
The pump in the Jacuzzi bath?
The baseboard heater, wall heater, towel rail?
We just have to guess these things :>)
Jan 01, 2016 | Home
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
Wiring back up a bathroom light bar
Employ a qualified electrician to wire it up correctly.
Mar 27, 2017 | Kichler Lighting 3127 - Jervis Bath Bars...
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Flip over bathroom plug in bath stuck & bath full :/
follow this steps and fix it. God bless you
  1. Remove the shower head from the pipe.
  2. Clean the arm threads and wrap them with plumbers' joint tape.
  3. Screw the head back on and hand-tighten it. Remove any excess compound or tape.
  4. Test and retighten as needed.
Repair a shower head that leaks at the swivel:
  1. Unscrew the shower-head body from the swivel-ball ring.
  2. Find the O-ring or a similar seal inside. Replace it and screw the shower head back into place.
  3. Turn off the water supply and open the faucet handle to relieve water pressure.
  4. Carefully loosen the coupling nuts at the shutoff valves and at the base of the faucet.
  5. Carefully remove the supply tubes.
  6. Remove the locknuts that hold the faucet to the sink and lift the faucet out.
  7. Clean the area where the old faucet sat.
  8. As needed, install the new spray hose and supply tubes, if any, through their holes in the sink.
  9. Set the rubber gasket that came with the faucet on the sink where it will be mounted. If no gasket is supplied, apply plumber's putty.
  10. Set the faucet into position and center it.
  11. From under the sink, attach the faucet locknuts to hold it to the sink.
  12. Reinstall the supply lines, then turn them on and test the faucet. Turn it on carefully because the line and faucet have air in them.
Nov 28, 2013 | Home
What kind of mirror should I use in my bathroom?
All bathrooms need a mirror - it's the place you are most likely to shave, do your facial care routine and dry your hair.
When choosing a mirror for the bathroom, pick one that is the same width as your vanity/ sink unit otherwise it won't blend with the design of the room.
Feb 18, 2013 | Home
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
When do you need to vent a bathroom sink?
You always need to vent a sink. If you do not vent the sink it will create a vacume and **** water, or air from the nearest fixture.. example, if you connect to the sewer line near a bath tub, when you run the sink water it will **** air from the bath tub drain. If it sucks a lot of air, you will smell the sewer odor since the water is no longer blocking it.
If you cannot run the vent to the roof, there is an in wall vent valve called a studor vent that may work. Get with someone at Lowes or Home depot to show you one.
Feb 09, 2011 | Home
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
I am considering fitting a Fortic tank. I require it to provide hot water to the kitchen and bathroom sinks and the bath. An indirect cylinder is currently installed because there was a Rayburn which...
what you have is better than a fortic. fortics should only be used if you have a lack of space to put in any thing else. if you are planning to heat water with the emersion just cap the ends that went to the rayburn and you are good to go. or fit a floor standing oil boiler and heat rads as well. you may have to add zone valves for that to keep water in the tankat the right temp
Jan 04, 2010 | Mansfield Plumbing Products Mansfield...
Nintendo DS Lite Console Logo
198 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
