Question about Water Heaters
Junkers gas water heater automatic ignition not working
My water heater stopped working however when I removed it from the wall and gave it a good shake and re-fixed it - it worked fine for about a week and then stopped. The ignition is not firing up and the gas is not coming through (can't be lit by hand) when the hot tap is turned on. It seems to me some sort of valve is sticking which also shuts off the gas.............any ideas
  • Anonymous Apr 18, 2009
    Our Junkers combination bioler has stopped firing up . it has in the past been able to reset by pressing the red lighted button..but now it won't light.
    Is there a reliable gas fitter in the ALCAIDESSA AREA
  • Anonymous Mar 26, 2014
    There is no hot water supply from my system Dux Deliverance DX. The gas does not seem to be igniting when the hot water tap is turned on. This used to only happen when is way raining heavy, now it will not work at all.
  • 34 Answers
Yes that is going to be the contoll valve on that heater. You can probley fix it very easy with the right part. You will need to locate a plumbing supply over there in the UK. Give them the make and model number and tell them you need a unitroll gas valve for it.
Posted on Feb 08, 2009
Is the junkers WR 11 Gas water heater ok for outside mounting
No all water heaters need to be mounted inside. Helps with the equipment efficiency, corrosion due to exposure to the elements, possibility of incoming water freezing. It\'s bad on electrical connections, the UV lite is hard on any plastic parts. These things are meant to be installed indoors.
Dec 04, 2014 | Water Water Heaters
Looking for manual for Junkers gas geyser 250 KV3 P3152500TAI
they all work the same
http://www.americanwaterheater.com/support/manuals/res-gas.pdf
Nov 08, 2014 | Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Flame burning too orange
You must get more air to water heater, and check venting .... immediate CO poison danger.
Call qualified plumber immediately.... because deadly carbon monoxide is not being vented properly.
http://waterheatertimer.org/Water-heater-safety-precautions.html#soot
Gene h
Mar 27, 2014 | Water Heaters
Junkers gas geysers not heating water much
between 60 and 75 degrees c as any hotter will scald you. Have the gas specialist check it out as it may not be getting enough gas flow to the burner either a badly adjusted regulator or a blockage in the gas tap or line.. You control the temp by the amount of water coming out of the tap as you found out when you attempted to restrict the water flow.
May 29, 2013 | Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
I have an Atwood G6A-8E water heater. It stopped working last year so I took it to Camping Wprld. Their R&I'd the tube and igniter. He cleaned to tube and adjusted the igniter. The water heater...
Have you verified that you have 12 Volts DC to gas valve when it is trying to ignite? If you have the little thermal cut-off ( looks like a small diode ) inside plastic sleeve going to terminal on thermostat, remove it and connect female end on that brown wire directly to thermostat terminal and see if it lights.If it does, get a new thermal cut-off. It's a safety device so don"t go without it. It shuts off gas to valve if there is a flame up.
Aug 14, 2011 | RTO Atwood Water Heater - 6 Gal LP
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Water Heaters Logo
5,179 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
