Question about Sony STR-DB780 Receiver
Audio out problem
I have been using the Sony DB 780 for 3 years with much satisfaction. As a result of moving houses the amp/receiver remained idle for one and a half years. Few days ago I wanted to put it back in place and realise that:
1. front speakers no output 2. sub woofer no output 3. rear speakers plays faintly 4. center speaker output excellent.
Could someone tell me what the problem may be and what could be done? Best regards.
bil
  • Bilal Mahomedkhan Feb 09, 2009
    thanks jamaica121.
    i've check all my settings, cables and speakers. seems like only the fronts and the sub have no output. you think they have a dedicated ic just for them?
    regards
    bil
    thanks jamaica121. i've check all my settings, cables and speakers. seems like only the fronts and the sub have no output. you think they have a dedicated ic just for them? regards bilĀ
    Problem Solver:
  • 3 Answers
Sounds like your sound output ic may have gone.this is normally connected to a heat sink.also check that sound output settings are ok before you go further
Posted on Feb 08, 2009
Was idling 1000 adjusted idle to 780 now truck wont start unless you step on fuel slightly,then starts immediately and idols at 780
Depending on the year make & model, nowadays the computer in in charge of the idle adjustments. Try to readjust it back to where it was & check the result. You may need an idle control valve, throttle positioning sensor, vacuum leak etc.
Sep 24, 2015 | Cars & Trucks
How do I set up receiver
HI YES YOURE GOING TO NEED A FEW RCA CABLES u. can use video 1 to plug youre tv in and use video 2 to plug in youre vcr ::::::::::connect youre speakers up to the red and black speaker terminals marked L & R..good luck
Jul 26, 2015 | Sony STR-DB1070 Receiver
Pioneer VSX-921 About a year old, and although it isn't defective, the volume is slowly moving down. (I mean over the months) When I got I i would set it at -55 dB to get a good sound level... Months...
You like it loud? Maybe your hearing is going... ;)
Seriously, this sounds like something to get fixed while it's still in warranty. It's not right.
May 07, 2014 | Audio Players & Recorders
On a sony str-dh710, is there any difference in the amp. level between setting the distance levels and the db levels? Also using the Video 2 input on the front of the reciever I'm not able to get any...
.. or read the manual about setup and getting multichannel audio from 2-channel sources. Calibration and Selecting a Sound Field.
Distance is linear spatial separation of two points. dB is audibility, sound pressure level, volume. The distance setting affects how the various channels are delayed to arrive at the primary listening position at the appropriate time to provide a plausible sound field. Simply making one or more speakers louder or softer will not affect the spatiality of it.
Apr 18, 2011 | Sony STRDH710
My Sherwood RD-6105 shuts off if I turn it up past 28 or 29 db (which isn't very loud). I'm using it in Dolby Digital mode. It even happens when I use it with my components that are analog. This just...
It's acting as if a short or near-short exists on the amp outputs at medium levels.
Disconnect one of your speakers at a time and try it. Make sure your speaker wires are tight and not shorting to anything and all channels have 6-ohms or more load.
Jan 16, 2011 | Sherwood RD-6105 Receiver
I am looking for a manual for the sony str-db 780 amp but in english can you please help me
Is it a US model? I can't find a listing at all direct from Sony. Is it STR-DB780 or STR-DB870?
For the 870 it's http://www.docs.sony.com/release/STRDB1070.PDF
Hope this helps
Jun 30, 2009 | Audio Players & Recorders
Marantz sr780 whole house system
try speaker a and b function unplug unit for a couple of hours. check your sound field.
Jun 01, 2009 | Marantz SR-780 Receiver
I am having audio issues with my Sony DCR-TVR900 NTSC Camcorder
If the problem is no audio recorded from the internal microphone, then it has likely failed. See http://www.bealecorner.com/trv900/trouble/micfix/index.html for a simple repair procedure you can do yourself.
Dec 17, 2008 | Sony Handycam DCR-TRV900 Mini DV Digital...
LOOKING FOR A MANUAL AND A REMOTE FOR MY STR-DB 780
Please download user manual of STR-DB870 from Sony Support.
Nov 20, 2008 | Sony STR-DB780 Receiver
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
Sony STR-DB780 Receiver Logo
276 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
