Question about Samsung BD-P1400 Blu-Ray Player
Split screen with component cables.
I have the Samsung BDP1500. I am having problems because when I hook up the component cables as recomended the image comes through as a split screen with the same intro screen on each half. How do I fix this?
  • 3 more comments
  • leatherneck0 Feb 08, 2009
    gopi20,
    Changing the cables did'nt work. The cables are hooked up right. What else could it be?
    It's not the wiring. What else.
    I've tried it with nothing but the BDPlayer plugged in. Still have the same problem.
    My TV is a JVC IArt. It does not have "Twin Picture" capability.
    Reset the TV. That didn't work.
  • Samsung Master
  • 19,396 Answers
The TV does not have picture in picture settings, or twin picture settings, but the blue ray has zoom and pip capabilities.
Just unplug the blue ray from power for ten minutes to reset its settings.
If after reset you still get the problem , then there is an internal fault, in that case contact Sony.
Posted on Feb 09, 2009
  • 360 Answers
Try adjusting the signal output of your dvd player
For Blu-ray Disc Players progressive scan
output : CONSUMERS SHOULD NOTE THAT NOT
ALL HIGH DEFINITION TELEVISION SETS ARE
FULLY COMPATIBLE WITH THIS PRODUCT AND
MAY CAUSE ARTIFACTS TO BE DISPLAYED IN
THE PICTURE. IN CASE OF PROGRESSIVE SCAN
PICTURE PROBLEMS, IT IS RECOMMENDED
THAT THE USER SWITCH THE CONNECTION TO
THE ‘STANDARD DEFINITION’ OUTPUT. IF THERE
ARE QUESTIONS REGARDING OUR TV SET
COMPATIBILITY WITH THIS PRODUCT, PLEASE
CONTACT OUR CUSTOMER SERVICE CENTER.
Thanks for using FixYa
clarkco
Posted on Feb 08, 2009
  • 217 Answers
This could be coz of the twin picture function activated on your TV please check
  • 1,800 Answers
This is occuring when a TV feature is Activated such as Twin Pic.
You can try reseting ur TV like intialiaze it and install the connection again between the B.ray Drive and TV.
Keep US updated plz.
  • 10,594 Answers
I think "Twin Picture" function is activated in TV because twin picture is able to present such effect.
Please check TV Menu and disable twin picture.
I do not see any problem with Samsung BD-P1500 blu ray player.
Thanks.
  • Shahid Electronics
    Shahid Electronics Feb 09, 2009
    Please hook blu ray with another TV just to confirm that player has problem. Upon confirmation, change blu ray menu for video out format as it seems some kind of sync delay.
  • 257 Answers
Hi, This sometimes happens when you have more than one video source. If you have component cables plugged in make sure you do not have an svideo or hdmi or other video source plugged into the same input. Good Luck!
  • Jim London
    Jim London Feb 08, 2009
    Hi, Lets try something else. If you have the player remote connected , disconnect it and only have the direct video source connected. We will keep trying but as you know long distance troubleshooting is tough. Good luck!
  • 153 Answers
It may be somekind of loose contact check ur wiring
    Master:
  • 848 Answers
Hi
Initially check whether you have connected properly...........try with another cables defective cable can cause this problem.....
How to hook up Xbox 360 Component HD AV Cable to Sony KP-53hs10
I would be surprised if this model has component inputs from its age and if so it is not a HD set.
Oct 31, 2012 | Sony KP-53HS10 TV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung hlp4667 only get a picture with HD input.
is there anything else hooked up to your tv other than cable or satellite? if no other components (dvd, vhs, etc) then you will get a snowy screen because the other inputs are for other components that are hooked up. a picture is showing on the HD input because you have cables hooked into that input.
Mar 15, 2009 | Samsung Televison & Video
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
Hi, I just purchased a Samsung series 3 330 model#LN40A330 I'am having problems with the AV inputs on back of television. I hooked up a DVD player to Component 1 it works fine Then I hooked up Nintendo...
I figured it out,
The solution to my problem was to update my video cables for my new HDTV.
I found out through trial and error that I can only have one Anolog device hooked up to the TV because with two Anolog devices hooked up the same way it must confuse the TV somehow making one of the inputs showing up in Black and White, So I purchased the color coded AV jacks and everthing works like a charm now.
Jun 21, 2008 | Samsung Televison & Video
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Oct 26, 2006 | Samsung SP-S4243 Television
Samsung BD-P1400 Blu-Ray Player Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
