Question about EliteGroup P4VXAD Motherboard
P4VXAD+ motherboard I have new TV PC card POWER SW the litle two pin cabel must go from a card to motherboard i don't know wher to put a cable! Thanks for any answer
    President:
  • 2,110 Answers
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Cabel connect problem on the bord power sw reset sw hdd led connecting pins ???? i don't have a plan of the bord
Please refer to the Product user manual. You can download it from the following link: -
http://europe.asrock.com/manual/775Dual-880Pro.pdf
Hope this helps!!
CreativeTECH
Nov 14, 2010 | Asrock 775Dual-880 Pro Motherboard
I'm having trouble knowing where to put the black orange and yellow cables. Where do they go?
do you mean the black orange and the yellow cables coming from the power supply if you don't know what is the power supply is it is somthing huge locatted in the upper part of you case if the are what i have guessed they will pe put onthe motherboard the are pins the same size on the mother board and don't worry they can pe put only in the right way no other way to be put on isa if this didn't help just take a picture of the cabels and send them to me and i will try to help you isa
Nov 07, 2009 | Compaq Presario 5BW284 (202493-003) PC...
Toshiba shuts dowm
pls .check your tv power cabel pin and plugg bitwin sparked or luss canaction [pls unplugged cabel pin and see tv. power cabel pin on top side black spot.]
pls try power cabel properly canact if loose replace with new.
NOTE:most of tv poblum is making power cabel loose. so canacting tv power cabel or power bord check with electrician
Oct 08, 2009 | Toshiba 42H81 42" Rear Projection...
HI! I was cleaning the inside of my e-machine W3502 and I putted off the 3 cords labeled Power LED green in color,HDD.LED red in color, and the POWER SW. Now i don't know how to put them back on in order....
look on the motherboard where all the cables are plugged in, It should list on the board in small letters what plugs in there. whats written on top goes on the top pins & bottom list should be the bottom pins.
Jan 14, 2009 | E-Machines eMachines Desktop PC
POWER SW cable: Old cabinet and Acer stock motherboard.?!
Here is the download site for Aopen motherboard. Download a manual and i am sure that the locations that you are looking for wil bbe illistrated. If not their are also 4 more pages of downloads for that MB.
http://download.aopen.com.tw/Default.aspx
Jan 05, 2009 | AOpen MX46L Motherboard
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
I need the diagram for the pwr sw leds reset sw
on the motherboard if there is the pin setup section that you plug them into it will indicate what each pin is for. it may not be the same as your old one but will be basicaly the same setup with + & - connections for the hard drive light ,power light , power on/off, speaker ect...
Oct 08, 2008 | Soyo P4X400 Dragon Ultra Motherboard
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
Can't connect front panel Power SW cable
On your board in the corner at bottom, you find pins for front panel Power Switch Cable, over there in small characters PWR SW is written, you can put your Power SW Wire there
Jan 02, 2008 | Intel D845HV (735858149143) Motherboard
EliteGroup P4VXAD Motherboard Logo
697 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
