Question about Cardo BTA II - Cellular phone Bluetooth adapter Wireless Headset
Pairing a bluetooth adapter without key
Is it possible to pair a bluetooth audio adapter (cardo bta 2 or similar) to a bluetooth headset without using a telephone or anything with numerical keys? Goal is to build a wireless microphone system.
  • Anonymous Mar 29, 2014
    same
    same
Hay the key is nothing more then a metal stylus try using a sewing pin in place of the stylus. it is metal and small enough to fit in the hole this will alow you to press the button and set it into pairing mode. good luck and have a nice day!
Posted on Mar 12, 2009
SOURCE:
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
Jun 02, 2010 | Rider Cardo Scala Q2 Multiset Headset...
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Apr 22, 2010 | Cardo scala 700LX Bluetooth Headset
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 07, 2010 | Cardo S-800 Bluetooth Headset Wireless...
How do i pair it wiyh my phone?
Try these:
  1. Turn your phone's bluetooth on. Maku sure your phone is discoverable.
  2. Press and hold call button on bluetooth headset until prompt appears on phone telling you to enter pairing code.
  3. Enter 0000 as default pairing code.
Sep 04, 2009 | Cardo scala 700LX Bluetooth Headset
HOW TO PAIR A BLUETOOTH HEADSET WITH A SAMSUNG YPP2 MP3 PLAYER
You have to go in to the blue tooth option on the menu of the p2. Then click search. Hit the sync button on the headset. It should find it in less than 20 seconds.
Jan 19, 2009 | Samsung Cardo Scala 500 Hands-free Headset...
Pairing
My motorola bluetooth will not pair w my cell lost code
May 07, 2008 | Cardo Systems Bluetooth Headse Wireless...
How to pair a Motorola D200 to a phone??
You will never be able to pair the d200 to a phone or another device, for this is a a2dp bluetooth dongle, that´s why it works with your headphones.
Mar 07, 2008 | Motorola Lands Phones
Cardo BTA II - Cellular phone Bluetooth adapter Wireless Headset Logo
334 people viewed this question
Top Cardo Radio Communications Experts
janvdb
Level 1 Expert
Tom Chichester
David
David
Level 1 Expert
Are you a Cardo Radio Communication Expert? Answer questions, earn points and help others
