Question about Acer AL1717 17" LCD Monitor
Acer AL1717 moniter hissing and goes black
Ok so my acer1717 moniter turns on for a second or so then it flickers n dies n it hisses... when i turn it on it does this twice ... sometimes it stays longer than other times but its nothing that i can work on... it only lasts like 3 seconds tops ... please help
  • 1 more comment
  • lovydovy Apr 25, 2009
    the monitor comes on, makes a loud hissing sound, then blanks off in one or two seconds. After a few seconds it does the same thing again, and then blanks off in a couple of seconds and then never comes back on. If i turn the monitor off, and then turn it on again, it repeats what i have said above.........
  • Ruwan Kumara
    Ruwan Kumara Jun 22, 2014
    hi, I had the same kind of prob with acer monitor. I just replaced the cap with same capacity, voltage & heating level & now my monitor works perfectly. Please do not try to this yourself if u have no knowledge in electronics. It's dangerous since the capacitor can hold high voltage even if disconnected from main supply. Contacting a electronic technician will be the best way.
  • Ruwan Kumara
    Again, the heating level is for this cap is 105. You should not use 85 (Normal) caps since it can explode or damage your monitor & also be dangerous. I used acer monitor for over 5 years now & it worked perfectly till yesterday.
Include me in the people burnt (no pun intended) by crappy quality Acer monitors. Will never buy their stuff again. Ironically, this infrequently used external monitor burnt out overnight, just a few hours after I had actually checked out and decided to buy an Acer Windows 8 15.6" i5 laptop. Definitely not buying Acer again.
Imran
Posted on Dec 09, 2012
    New Friend:
I had the same kind of prob with my acer monitor. I just replaced the cap with same capacity, voltage & heating level & now my monitor works perfectly.
Please do not try to this yourself if u have less knowledge in electronics. It's dangerous since the capacitor can hold high voltage even if disconnected from mains supply. Contacting a electronic technician will be the best way.
Again, the temperature level is for this cap is 105. You should not use 85 (Normal temperature) caps since it can explode or damage your monitor & also be dangerous. I used my acer monitor for over 5 years & it worked perfectly till yesterday. I think it's still good and usable..
If anyone need more help regarding this, contact me on
sumagasoft com
Posted on Jun 22, 2014
    New Friend:
Mine does this, if i repeatedly keep turning it on and off, it can take between 3 to 30 tries, but eventually itll stay on.
Posted on Nov 28, 2013
You can buy the Power-Inverter board on ebay.
Posted on Mar 14, 2010
  • Acer Master
  • 2,404 Answers
Monitor is fried, problem with the inverter but you can't buy parts for it and would have to get a new monitor. I've seen the problem many times before.
Posted on Feb 08, 2009
SOURCE:
Monitor Goes Black
there is a blown capacitor on one of the boards inside display
Feb 09, 2013 | Princeton Digital Computers & Internet
My VX1962wm monitor began making a almost hissing noise and has not displayed what it should be properly since it first made that noise. The monitor will turn on when I turn on my PC, but it makes the...
Your monitor has high voltage leak from one of the bulbs end to the ground. This leak is in form of an arc starting from the solder on the bulb where the wire ends and ending on the metal frame of the LCD.
The current rises and electronic protection in the inverter turns it off.
You have to take apart the monitor, then the LCD to find the broken insulation and to resolder and insolate the joint between the high voltage wire and the light bulb.
Aug 01, 2010 | ViewSonic VX1962wm LCD Monitor
Acer LCD monitor goes black after 1 second
More likely to be bad caps (bulging top), look for that first, the caps may be out gassing, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | Computers & Internet
Tv hisses and goes off
Whats the model number of your set and I will assist you as the hissing is most likely the flyback or the HV splitter. The model number will help me decide which. also let me know if the hissing is louder at the front of the set or louder at the rear.
May 30, 2009 | Televison & Video
Ionic Breeze - Black Quadra won't stop hissing
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
Jan 30, 2009 | Air Purifiers
Black lines in Acer AL1717
On the power supply PCB are two 25V 220uf capacitors that will be leading. Replace them and the picture should be back to normal.
Dec 28, 2008 | Acer AL1717 17" LCD Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
745 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
