Question about Bernina Artista 180
Bernina 930 won't zig zag
My Bernina 930 has stopped zig zag. I don't use it that often, but when I do I make sure to clean it and oil it. I was sewing on fleece when I noticed the needle would just "float" from side to side when the stitch width was adjusted to anything except straight. I finished the project then looked more closely at my machine. The Stitch width knob now doesn't work at all. I was able to move the button hole maker to the first detnent, but now that won't budge, either. Thank you for your help. I'm a little hesitant to take it to the local Bernina dealer as it just feels like they only want to sell me a new machine.
  • 202 Answers
You will need to remove the top cover. 2 screws one of which is under the bobbinwinder lid. They only turn a half turn to release. After opening the top cover and if you watch what goes on inside from the top, move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Hope I helped.
Posted on Feb 11, 2009
    New Friend:
  • 186 Answers
You probably need to take it in to the shop, the needle position knob is bound up. It's worth spending the money, this is a good machine. You can try to soak everything with penetrating oil over night and carefully try to move the knob, you may be lucky and it will free up.
Posted on Feb 08, 2009
Bernina 1230 - ZigZag stich is intermittent - sometimes it will only stitch on one side instead of switching back and forth???
Make sure to install a brand new needle. Sometimes a damaged needle will not connect on a zig-zag stitch.
I have a 930 Record that has to be oiled frequently. Don't know if that's the case for your 1230. Some of the mechanisms hang up on the 930 if not lubed at least once a year. I use liquid Tri-Flow Synthetic Lube, avlb at the hardware store or bike shop.
Nov 19, 2017 | Bernina Sewing Machines
The zig zag and other stitches does not work. This is on the Bernina 930 which has not been used for several months.
Bet the machine hasn't been thoroughly cleaned and lubed in quite a while. The mechanics have seized due to old, dry oil in the moving parts. Lots of patience, time, good quality lube, and a handheld hairdryer will probably take care of it.
Be sure to move the levers and dials and apply a drop or two of lube there too. The most difficult one to reach is the feed dog dial mechanism. Unfortunately, the feed dogs are not changed very often so it is also one of the most likely to seize.
BEWARE, on your 930, there is a basting stitch mechanism accessible about the midway point of the slit where the take-up lever travels. Do NOT apply lube to this area as it will most likely cause the basting stitch to seize. It has seized when the needle mechanism rises to the top and refuses to lower again, no matter what you try. (Bernina oil diagram below.)
Wheel on right side that controls the needle up and down is very tight...
Mar 05, 2017 | Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
Bernina Record 930 electronic sewing machine will not zigzag
How long has it been since it has been cleaned and oiled? Mechanical machines, like the 930, need frequent oiling with fresh, good quality oil. (You may want to pick up some Bernina oil for CB Hook machines.)
Apply only 1-2 drops of oil in each spot (look for oil ports--little holes where oil should be placed). Do NOT oil in the middle of the needlebar. This is where the basting stitch mechanism resides and if you oil it, the basting stitch may lock up requiring service.
A good suggestion for oiling is to gently rotate the handwheel and watch where metal rubs against metal. Apply a couple of drops of oil in each spot. Do NOT oil the metal cams, the two plastic gears, or the belt. Next, gently move the selector levers and apply oil there too.
If it has been quite some time since you've oiled, you may have to re-apply oil to get things lubed again. If the zig-zag is still not working, you can direct a handheld hairdryer into the internal mechanism and apply heated air. (Be careful, the metal can get hot to the touch!) Repeat the oil and heat until the zig-zag selector begins to work.
The other part that may be frozen is the upper left side where the light bulb resides (you'll have to remove the screws that hold the covering on). Set the machine to zig-zag and move the handwheel and watch where things move there, also work the lever to raise/lower the presser foot. Again, AVOID the middle of the needlebar==basting stitch mechanism.
Your machine should be oiled every time you finish a big sewing job, every time you install a new bobbin, or every six months if not in frequent use. The bobbin race should be oiled more frequently. When you are familiar with your machine, you will recognize the change in the machine's sound and know that it needs some TLC--cleaning/oiling.
Nov 13, 2015 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
Bernina 930 Electronic
Try cleaning and oiling your machine (refer to the owner's manual). Perhaps the stitch width selector has become stuck with old oil. Mechanical Berninas should be cleaned and oiled regularly--it every time a bobbin is changed, every 8 hours of constant sewing, or every 6 months of non-use.
Dec 10, 2013 | Bernina Sewing Machines
Zig zag problem on Bernina 910
Have you rethreaded the machine, making sure to get the thread between the tension discs?
Jan 31, 2013 | Bernina Sewing Machines
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Sewing Machines Logo
737 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
