Question about Canon PIXMA MP160 All-In-One InkJet Printer
Unidentified error code
When i turned on my printer, a code 'E & 0' appeared which is not stated in the guidebook. after i turned off all the plugs and turn on back, 'E 5 & '1' appeared (it shows that the FINE cartridge errors have occurred). so i followed the guide book to rearrange the cartridge. finally, 'E 4 & 2' appeared and this isn't also stated in the guidebook and i've done many things to repair my printer but nothing happened. help me please
  • 2,404 Answers
You can try to deactivate the ink level detection function but I'm also wondering if maybe some of the cartridges are bad? They have little green boards on them in the back of the cartridge and if those go bad it can cause all kind of havoc. Only way to really know would be to replace the cartridges and see if that makes the problem go away but I know that would be expensive.
Try deactivating the ink level detection function first though and see how that goes.
Posted on Feb 08, 2009
How to reset error code C452 in the Toshiba e studio 2006
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "62" to "0", then
press [OK] (to cancel [C452]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Jun 13, 2015 | Toshiba Office Equipment & Supplies
Error code cof32 & c0070 at bizhub 210 how con i fix it?
Solution for Error code C0F32
1-Turn the machine ON. 2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
Error Code C0070
Solution:
1- Open the front door and bring the bottle out.Now restart the machine.if the code appears then open the toner hopper section.Toner hopper drive motor is not working, Dis mental the hopper section.
Jan 27, 2014 | Toshiba E-Studio167 Copier
Error p08
Repair, Canon MP258 code error P08
1. The printer is off and plug the power cord.
2. Press the button STOP / RESET and hold, then press and hold the POWER button
3. POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed
4. Release both buttons simultaneously
5. The printer will proceed in a while, then the LCD panel will show the number zero (0)
6. Computer will detect NEW DEVICE (Canon MP258 series Printer (Copy 1)), Ignore it
7. Press the power button, then the printer will turn off. If the printer does not turn off, unplug the power cord.
8. Press the power button again, then the printer will be ready to use.
Nov 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer canon pixma mp258 have error....P08 appear on the LED
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge.
Step to resolv this error
Step 1 : Turn Off Printer
Step 2 : Remove Cartridge
Step 3 : Refilling the cartridge
Step 4 : Reinstall the cartridge
Step 5 : Turn The printer ON
If it still does not work you can use the following methods
How To Reset MP 258 error 5200
Step 1 : The printer is off and plug the power cord.
Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button
Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
Step 4 : Release both buttons simultaneously
Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0)
Step 6 : Computer will detect NEW DEVICE, Ignore it...
Step 7 : Press the power button, then the printer will turn off
Step 8 : Press the power button again, then the printer will be ready to use
Nov 16, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Feb 21, 2010 | Canon PIXMA MP190 All-In-One InkJet...
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
An error message stating that the device overloaded the usb port appears (yellow light at the port).
Go to the device manager and uninstall all usb devices. Turn off computer, unplug all usb, reboot twice, plug usb in again. Also helpful are troubleshooting usb articles here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 21, 2009 | HP PhotoSmart 7960 InkJet Printer
Toshiba e-studio error code
It is abnormal temperature in the fuser*, thermistor error.
Maybe replacing fuser would help. But better contact service person.
*fuser, the part of a laser printer that melts the toner onto the medium. It consists of a hot roller and a back-up roller.
Feb 13, 2008 | Office Equipment & Supplies
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
