Question about Microsoft Zune JS8-00001 Digital Media Player
Usb device not recognized when i plug in my zune
I have a 120gb zune, plug in the usb cable and the computer says "usb device not recognized".
  • YAsir T Mar 08, 2009
    Does not recognize when i connect it and i have the software downladed and i also have the right cable for it to.
  • Dive24 Mar 20, 2009
    USB device not recognized.....followed all of microsofts troubleshooting recommendations....updates etc. Still same problem.
Maybe your usb has a prob... try it on other computer
Posted on Feb 08, 2009
My Zune HD 16 gig MP3 won't get recognized by my computer. I've plugged it into all four of the USB ports on my computer and my Dad's computer and it still hasn't worked. The Zune is instead replaced by a...
Ok this is either a usb hardware problem, a cable problem, or a zune problem.
Basically to find out which you need to do a process of elimination. plug in the zune and when it fails then unplug it and plug a different device into the cable (preferable as this eliminates cable and usb as probelm in one go) or into the usb port. Next is try a differant cable. And finally try the zune on a different computer. If the zune isn't recognized on a different computer it could be the cable or zune. Try a differant cable again.
Usually the most common problem is the device followed by the cable. Unfortunately the only reliable fix is to replace which ever is the problem.The cable ends sometimes get damaged or loose and you don;t get a good connection. Sometimes you can check this with a quick wiggle on the ends. If it suddenly gets recognized then the cable is the problem.If its the device there really isn;t anything you can do but replace it.
Feb 27, 2011 | Computers & Internet
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
Turn off the CPU pull off the power cable, unplug all usb cables, Let it sit for about 15 mins. Plug it back in start the CPU plug in your device. This will reset the motherboard, as just turning off CPU the motherboard still has power. If still does not work, you can either re-do windows, or get a USB/PCI Port Card, thatll have like 5 usb ports on it. And try that.
Aug 03, 2009 | Microsoft Zune JS8-00001 Digital Media...
Trying to plug in zune but computer won't recognize it.
You might need to reinstall the drivers, or update your USB port drivers.
A nice zune troubleshooting guide on this is available on fixing zune device errors.
Hope it helps.
Jules
Jul 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune Player
Hold down the back and up buttons on your Zune until the screen goes black. You should see your Zune reset. If you have your Zune connected to your PC during this, you will see that Windows will immediately recognize the device.
Jun 26, 2009 | Sony PlayStation Portable (PSP) Console
maybe the USB is rusty or dirty...it also happens to me
May 05, 2009 | Microsoft Zune JS8-00001 Digital Media...
do you have the software installed? or a older version installed? if so that could be your problem with the drivers. try downloading the zune 3.0 software directly from the zune website instead of updating ,  here is the link to the download page
http://www.zune.net/en-us/software/download/default.htm
Make sure you uninstall any previous zune software first!
Hope this Helps
A+Support
Apr 10, 2009 | Microsoft Zune JS8-00001 Digital Media...
I have a brand new Zune 8 GB player, given as a gift. I downloaded the Zune Software, but when I connect the player by the USB cable, the Zune program does not recognize a Zune as being connected. Also,...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps
ALL YOUR BASE BELONG TO US - is a video that must have been loaded on the Zune previously.
if all else fails...
If you connected the ZUNE to your computer before installing the software the computer may have installed it as a different device.
Go to Control Panel - then System - Device Manager. Plug in ZUNE player and see if any new devices show as being connected. BE CAREFUL IN DEVICE MANAGER THOUGH, IF YOU UNINSTALL THE WRONG ITEM, IT COULD MESS YOUR COMPUTER UP.
If this works rate it a FIX-YA!
Dec 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
743 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
