Question about D-Link DFE-530TX+ Ethernet ED100W Network Adapter
Mbps...peoblem in connecting in internet
What should i do if my Mbps is 10 only..i need 100 to connect in internet...even if its conncted,sometimes theres a problems..in terms of always disconnect...what should i do?
  • Anonymous Apr 22, 2009
    the lan card sign is ok, but i can't go anywhere on the network ??
مشكورررررررررررررررررررررر
Posted on Feb 28, 2009
Driver nvidia nforce 10 100 1000 mbps ethernet
Go to the support website of your motherboard manufacturer (if you have a brand name computer such as Dell, Acer, etc. go to their website). Click on Support, then locate the Downloads page for your exact model. Find the LAN/ethernet drivers for your system there.
May 15, 2014 | Intel Computers & Internet
Annoying Wireless network connection problems!
Try changing the channel number in the router for the Wi FI add 3 to the minimum channel number.
It is possible you have a neighbour with wi fi and by adding three to the channel number you give some space separation to allow more bandwidth on the WI FI channel.
when this slow down occurs ping the router address (default gateway ip) and see if ping is quick. This will eliminate WI FI as slow point. Try using tracert instead of ping to see if bottlenecks occur in network or internet.
Mar 06, 2017 | Computers & Internet
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to www.speedtest.net and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Mar 17, 2011 | Linksys E3000 Wireless Router
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
My internet speed is too slow, it only recieve 10Mbps as i view it on Lan. how can i make it to 100Mpbs? By the way my internet is connected on built-in lan (through Motherboard) do i have to buy Lan card...
So from Network Connections, you right-click the LAN connection, select status, and it displays Speed: 10 Mbps ?
If you select the Properties button from that dialog, and then with network card showing, select the Configure button; and from the properties shown on the Advanced tab, select Link Speed & Duplex. The value should be Auto Detect. If the LAN is configured correctly for 100 Mbps, you should get it.
Mar 01, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Running at 10 mbps
There's possibility that the network (router/modem/switch) you're trying to connect has limit to up to 10 Mbps only. Or it can be that the current LinkSpeed of the Ethernet adapter might be forced to 10 Mbps. Do the following to check this setting:
  1. Go to Control Panel> Network Connections.
  2. On Network Connections, look for Local Area Connection (for the D-Link adapter). Right click it then go to Properties.
  3. On Properties window, click Configure button.
  4. On the next window, go to Advanced tab.
  5. Look for Media Type, Connection Type, or LinkSpeed and Duplex Mode.
If the value is set to Auto Negotiation/ Auto/ AutoSense, try to force it to 100 Mbps.
Jul 22, 2008 | D-Link DFE-530TX Network Adapter
Slow internet
I suspect that the DE-528 (discontinued card by the way) is only a 10 mbps card. Unless you are doing some heavy duty video the card would be fine. Otherwise replace it with a 100 mbps card.
Feb 08, 2008 | D-Link DE-528 Network Adapter
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
D-Link DFE-530TX+ Ethernet ED100W Network Adapter Logo
94 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
