Question about Kenwood DDX-512 Car DVD Player
Unlocking audio and equalizer set up
I recently purchased a ddx512 an cannot unlock the audio set up or equalizer is there a master code? my subs are way too loud and u cannot hear none of the other speakers because of this
    Problem Solver:
  • 5 Answers
Go to set up memory and at the top theres two options. Unlock and lock. Tap unlock and go back should be good.
Posted on May 09, 2009
Sometimes you have to select "standby" as the source to change certain settings.
Posted on Jul 29, 2009
Onkyo HT-S3400 not showing DTS-HD Master Audio
Hello, with the source playing press the display button on the remote. What format do you see? Thank you, CB
Apr 05, 2017 | Onkyo 5.1-Channel Home Theater Package...
Hi, We recently purchase a used renault master van at work. The trouble is the radio requires it's code but one was not supplied and none of the documentation has it written down. The only number I have...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Aug 31, 2010 | Car Audio & Video
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Nokia 5220 security code
your master code is 344450772x last digit garbeld
May 27, 2009 | Nokia 5220 XpressMusic Cellular Phone
Master unlock code for a kenwood ddx512
my kenwood DDX512 IS LOCK I NEED A CODE TO UNLOCK IT
Mar 24, 2009 | Kenwood DDX-512 Car DVD Player
I cant turn my sub on
I had the same iss and what I finally figured out through the use of the book and just messing with it is- go to the menu seletion screes should be the upper right button on the screen or what would be a main menu of all the options - then scroll down to the next menu page there should be one button listed as standby- click it- then go back through your menus and adjust where needed for the sub. Then just adjust all you things to max- it worked for me. the lables for audio nad interface still had a lock on it but after hitting the standby button to can then change your settings that were previously locked up. then once done just go back to your tuner or dvd etc.. to get out of set up menu.
Nov 17, 2008 | Kenwood KVT-617DVD Car DVD Player
Djm600 on my hedphones i cant hear master, just cue..
it is a loose connection or crack or cold solder joints,that cause to malfunction inside , needs to resolder or reheating by using a hot air,after resoldering clean the circuit board by a laquer thinner..
Jul 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
Music plays, but vocals are weak
Check and make sure you hook up the speaker wires correctly to the stereo, they are color coded. This unit does not have manual equalizer settings.
Jan 08, 2007 | Sharp CD-XP7700 CD Shelf System
Kenwood DDX-512 Car DVD Player Logo
1,322 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
