I 've recently bought a Targus mini notebook optical mouse (PAUM010E). When I connect the device with my notebook (BenQ JoyBook A33E), windows detect the mouse without any problem. If I reboot the pc and leave the mouse in the usb connector, the mouse doesn't react any more. In the 'device manager' I find an entry 'Unknown device' under the 'USB-Controller' node.
When I disconnect the mouse, the 'Unknown device' entry disappears. If I then reconnect the mouse, everything works perfect.
I've already re-installed the USB-Controllers but nothing changed.
I also tried the mouse on other notebooks: - notebook with XP Pro: no problems - notebook with XP Home: same problem (connection lost after reboot).
It seems this only happens with Windows XP Home.
Does anyone have a solution for this strange behavior?
Show your appreciation by commenting on USB connection lost after reboot:
Solution #3
posted on Aug 01, 2007
jessie25 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Disconnect and reconnect as you've been doing. For whatever reason, your laptop is not enumerating USB devices perfectly during a startup. Might check for a BIOS update from the manufacturer. Only update if the package description addresses a problem that you're having.
Side note: Something I've done on my portable is to disable "sleep" to USB devices. Drains a bit of battery life but USB devices stay live instead of disappearing. Look for power management settings in a device's properties (while in Device Manager). If available, you'll see a Power Management tab where you can customize.
-- Sharon F MS-MVP ~ Windows Shell/User
Was this solution helpful? Show your Appreciation by rating it:
