Question about Bose 901 VI Main / Stereo Speaker
Bose 901 series V speakers
I just inherited two in great condition but the previous owner threw away the receiver because the lights didn't work anymore. Is there any other receiver (less expensive) I could hook these up to and have them work properly?
  • 3 Answers
Use a dedicated amp for ur 901s..and like the guru said,if ur doing multi channel amplification,just get ur front signal from ur control amp and feed it to ur 901 amp through the 901 eq.i used to work for bose as a service tech here in okinawa ,japan.
Posted on Jun 12, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, there is no specific receiver coupled to the 901 series of Bose speakers. Rather, there is an equalizer which serves as an active enhancer/band pass filter for the 901 to operate at its best on specific frequency.Before the 5.1, these equalizers are used through the Tape IN/OUT to received the audio signals, process them and feed them back into the receiver. In todays current designs of receivers and amplifiers, this equalizer would need not be used since most have their own sound processors (Dolby, DTS & others). In some other set-ups, 901s are used as center or front speakers.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
    Brigadier General:
  • 8,546 Answers
Actually, back in the late-70's, early-80's, Bose did make a couple of receivers that had the 901-specific EQ built-in. But that was for stereo only and pre-digital age.
I auditioned it with some Bose 901-III's, which had a three-wire interface to each speaker, as I recall, that allowed the receiver to vary the ratio of the outward-facing rear panels to the inward-facing rear panels to suit your tastes and the nature of the recording. Essentially, you could vary the apparent width of the soundfield - wide for large orchestral recordings through narrow for a string quartet, for example.
I heard Lucky Man by ELP at ear-bleeding levels and when the MOOG solo at the end came by the sales guy narrowed the field and it knocked my socks off. It was stunning.
If I ever have a chance to cop one of these puppies cheap, I might pick it up. I've had a lot of Bose in my life, from the Bose 301 series 1, 2 and 4, Bose 901-V (all still in use) and even the Bose after-market car speaker/amp system (model 1401??) in 1981 which, regrettably, went with the trade-in.
For you here and now: your best bet is to find an Active EQ on eBay that matches the series of your speakers.
To employ it in a modern AV multichannel rig:
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Posted on Nov 30, 2009
Harmon kardon avr 146 with Bose 901 EQ VI
Bose is a pain in the back like Apple. Everything they make is proprietary or it won\'t work. The 901 series is one of them.
Nov 22, 2013 | Bose Audio Players & Recorders
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
I have the bose 901 wallnut sceries i have yet to find a conpatible reciver to run them
For stereo audio only: Any powerful receiver with at least one Tape Monitor loop will work. No other speakers types (excpet 901 -1 or -2) will be supported by the receiver running the 901's. 901 series 1's are very power hungry so figure on 150 REAL watts per channel and clean.
For multichannel audio and the 901's as the front speakers: Any AV Receiver with a set of Preamp Outputs for Front L and R; AND a separate HIGH-powered amplifier to drive the 901's ONLY.
May 29, 2010 | Bose 901 VI Main / Stereo Speaker
I just enherited a pair of bose 901 speakers
My suggestion is do not hook the 901's directly to the Onkyo. It is compatable, but they WANT more than what the receiver can give them. I suggest going and getting a dedicated amplifier for them. Trust me, you'll be a lot happier going that route.
May 27, 2010 | Audio Players & Recorders
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
Bose 901 series 6
have you tried EBAY
Dec 22, 2008 | Bose 901 CD Player
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
1,367 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
