Question about LG Microwave Ovens
Microwave Magnetron tube has arced
The magnetron in our Bosch HMB405/01 microwave has arced and burned the interior wall of the microwave. The wall surrounding the opening to the magnetron is burned enough that the metal is pitted. Obviously the tube needs replacement. What else needs to be done?
Thanks
Tom Quattlebaum
After few seconds the cooking cycle has started, the magnetron in my BAJAJ microwave(don't know model number) sparks outside at wall & waveguide cover. It heat ups the food during that interval. It burns the little area around its opening and waveguide cover.
Is Diode Tube also faulty or should I just replace Waveguide & clean+repaint the wall ?
Thank you.
Murtuza Bharmal
India
    Problem Solver:
  • 17 Answers
REPLCE THE MAG TUBE AND ***
Posted on Feb 08, 2009
My Bosch Micro HMB405 started sparking/arcing with a burning smell. I had an empty plate in there. Was trying to warm a clear glass dinner plate. Did I kill the magnatron by putting an empty plate in the...
Michelle,
You may have killed the magnetron but you may not have either. If you can take that cover plate off, you may find that there is grease build up behind it and that needs to be cleaned off. Grease can build up there without you even realizing it and after a while it can catch fire from the heat created by the magnetron. You should never put any empty plate or container in a microwave because the magnetron needs to have something for the waves to hit. Hope this helps.
Mar 25, 2015 | Bosch Microwave Ovens
Is the mica cover crucial?
sad to say but YES it is critical . .
Mar 25, 2015 | In Microwave Ovens
Ny microwave is arcing up by the stirrer motor even after the motor is disconnected
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may also have to replace the capacitor. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 26, 2013 | GE XL1800 1100 Watts Microwave Oven
Sparking inside microwave door
There is exposed metal, when magnetron is running it will arc if there is exposed metal in the interior cavity which is more common, I have not seen this inside microwave door, inspect door carefully when you open it to see if there are bare spots. The manufacture use to sell microwave cavity paint to prevent this very problem, if this is not corrected it will short out the magnetron.
Jun 09, 2012 | Neff B7740N0GB Microwave Oven
Sharp R408LS keeps sparking after minimal use. This is our 3rd one. This is mounted on an inside cabintet.
The magnetron is arcing in the interior and will eventually burn out. Check the inside for bare metal or food particals, if okay! the magnetron is breaking down and will eventually go.
Apr 21, 2012 | Sharp R408LS Stainless Steel 1100 Watts...
I have a GE Profile Advandium 120 SCA1000DWW03 microwave. Recently noticed arcing or sparking at the base of the back wall when microwaving. Any ideas or solutions? Was purchased about 5-6 years ago
This is not good, the magnetron is arcing because there is exposed metal. The manufacture provides a special enamel white paint that insulates the interior to prevent this. I would contact GE or appliance repairman and not use the oven until this is dealt with, running the microwave unchecked will eventually burn out the magnetron.
Feb 06, 2011 | GE Microwave Ovens
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from hardware stores, department stores or appliance parts stores.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Dec 03, 2008 | Microwave Ovens
Microwave Ovens Logo
794 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
