Question about HP Pavilion dv6000z Notebook
I spilled water on my laptop
Five days ago i was drinking water at my laptop which is Toshiba portege 7010CT and i spilled it out all over my laptop while it was on.immediately i turn off ,cleaned with a piece of cloth and put it up side-down.
Now it is five days ,it is not working
when i plug the socket the battery light and the computer light is on,but the computer is not starting and the plug light is off
i have never assemble or reassemble a laptop,but i do not have a problem with the desktop.
therefore ,would you please help me what i should do?
if i have to open and clean it thoroughly ,would you please show me how to do it.
i appreciate your help Hii ,
I have golden fish on my table along with the laptop, today i had to change water for fish and i did, but while putting it back glass slided through my figures and i was about to drop down aquarium pot but some how manged to hold it in that process spilled little water on laptop which was turned on!, the screen turned off immediately...i tried several times to turn on ...but all my efforts are in vain ...
I wish my laptop works!
could you please suggest me some thing ?
  • 1 more comment
  • jaya123456 Feb 08, 2009
    Hey ,
    I split considerable amount of water on the table too when i split water on the laptop, water being a bad conductor of electricity in this case turned off the battery first thus turning off the laptop immediately and stopping any further damage. I have dried up the battery and laptop for a day now and it works perfectly ! thank god ...looks like an exception.
    Thanks a lot for the suggestion.
  • Anonymous Feb 10, 2009
    spilled coke on keypad computer still works keys are sticking how do we go about that to order new pad? and to replace old have hp pavilion
  • GomaRampen May 11, 2010
    ok u can try this warm your hoven up to 50 to 60 dgrees and put your laptop in there for 1 houre then u can try to start it up
    Problem Solver:
  • 11 Answers
As was said previously, once you tried to start the PC without completely drying it out, you fried components and now you have an expensive paper weight.
If it is important to you, you can get a new or used motherboard (off Ebay) and power supplies if necessary, but paying someone to remove the old put in the new, and repair any other problems it may have, will cost you more then the PC is worth.
New prices are falling fast these days. The el- cheap o's E machines and Acer products are below $300. Next time follow the rules of unplug, remove battery immediately. Dry out completely following the ideas given, if ya use the oven, be careful you don't melt the plastic. I use hair blower (medium hot setting) to dry out components when needed. Use paper towels and tooth picks gently to stick in any area you can to try to get the moisture out.
Any moisture left will cause immediate damage when electrical current is supplied via wall outlet or battery, so check and recheck before you turn it on. Patience is key here, panicking and turning it on before you should will surely cause damage.
I've brought back many drenched cameras, phones, laptops by being patient and making sure every possible area is purged of moisture. Patience is needed, at night set it up over a heat duct so the hot air blows over and through the product. During the day let the sun shine on it as well, not to the point it melts anything, but keeps the unit hot enough to evaporate moisture.
When you believe all possible moisture is gone, then turn it on. You might be lucky and have your item for an indefinite period of time, or like in the case of this laptop, an expensive paper weight.
One other idea, there is electrical cleaning products that use acetone to clean electrical connections. You can spray this all over the opened laptop to push the moisture out and the spray will evaporate. If you can't find this, brakelean for brake parts on a car is similar to these electrical cleaners and will work and evaporate leaving little to no trace it was there. take the screws out of the case and gently take them off the unit (of course no electrical current is supplied while doing this) Then spray the motherboard and components liberally forcing it into nooks and crevaces, and it will force the water out.
Again let it dry over a period of time even after all your cleaning efforts. If you did it right, you got it back in working condition. Good luck.
Posted on Feb 11, 2009
  • 778 Answers
Sorry about your laptop, I don't think there is anything you can do about it now except salvage components that didn't get fried.
For future reference: You should unplug, power down, and remove batteries immediately when electronics are contaminated by liquids. Then you can attempt to dry them out, but don't be in a hurry to re apply power, as if there is any liquid shorting circuits, it will cause further damage to the device. Warm air from a blow dryer with all possible openings opened on the device and changing its position periodically and continue for a day or so after all signs of moisture are gone and you may have half of a chance of reviving the device (in this case your laptop).
You can try this now, but after five days of attempts to restart the laptop with power to it, I doubt it will work.
Good luck in the future.
Posted on Feb 08, 2009
Toshiba leading innovation
Hi Branden,
Could you please try to remove the battery and wait for 30 sec. Again insert the battery and turn on the machine after 30 sec.
Aug 10, 2014 | Toshiba SATELLITE C855-S5900 Laptop Screen...
Stuck on toshiba logo screen.
Dear Branden,
Please remove the battery and wait for 30 sec, after that insert the battery back and turn on the machine
Aug 10, 2014 | Toshiba SatelliteR C855D-S5900 Laptop...
Dead laptop
i believe when u spilled the water more then just the motherboard was damaged i do not think replacing the motther board will fix all of the problems
Aug 22, 2009 | Toshiba Portege 3110CT (P000278510)...
Toshiba R100 Laptop keyboard won't work
Water might have had damaged the keyboard.
Solution, get a new keyboard and replace it....or
get a USA regular desktop keyboard, plug it into one USA connectors, and use it.
It will work too
Please don't forget to rate if this answer helps you.
Jun 23, 2009 | Toshiba Portege R100 Notebook
plz ask your vendor for help because it is under warranty
Dec 17, 2008 | Toshiba Satellite A45-S120 Notebook
Spill on do I clean
ok -
Disassembly guides with pictures:
How to remove keyboard.
Remove laptop LCD screen.
ONLY clean with 95% - 99% rubbing alcohol, then wait till COMPLETLY dry before re-assembling.
Hope this helps.
Jul 03, 2008 | Computers & Internet
To fix my laptop
motherboard is fried..maybe around 125 to 200...not too hard to fix..I'd recommend a new uP too, and maybe memory sticks..
check your warranty here
Feb 21, 2008 | Toshiba Portege R100 Notebook
since you spilled the water when the laptop was on, the internal ciruits could have been short ciruited. you cannot repair it yourself. please contact a nearby service center. they will give you the information regarding whether it can be fixed or not. but my guess is that it cannot be fixed easily. beacause short ciruits generally blows of the ciruit completely and things like soldering also won't help.
good luck
Feb 06, 2008 | Toshiba Portege 7200CTe Notebook
No power
Any hope you may have left other than an expensive repair, is to remove the battery and leave the unit in an airing cupboard for a week and pray. Then replace the battery and try again. No change - then nothing lost. I know it's basic, and best done as soon as the damage was done, but has worked for me in similar circumstances. Don't be tempted to use a warm oven.
Jan 08, 2008 | Toshiba Portege M400-S5032X Tablet PC
HP Pavilion dv6000z Notebook Logo
1,744 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
