Question about Dell Photo 964 All-In-One InkJet Printer
Printer not printing in color; new cartridge, tests are fine
I installed a new cartridge, and, my printer (Lexmark Z715) printed a "test" page with blue and black designs. The page prints perfectly with no problems at all, but, when I try to print anything out, it is only black and white. The test pages print perfectly, but, only them. It is making me CRAZY! Please help
  • k_joyce Apr 08, 2009
    Dell Photo AIO Printer 926 wont print in colour. I can photo copy and print in colour, i can print an alignment page in color but it will not print any other document in colour...PLEASE HELP!!!!
    President:
  • 1,179 Answers
Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
Posted on Feb 08, 2009
I installed the Lexmark z715 printer driver on my Mac and it is connected fine, but when you attempt to print documents, it prints blank pages instead. The ink cartridges are brand new. Please help me...
Ok, you need to clean the print heads they are probally clogged, what operating system are you using on your computer? I can walk you thru on what to do, very simple, if you have windows xp, do this: Go to start then all programs then go to your printer, there should be an option to align paper, clean print heads, print test page, you need to pick clean print heads, then after that print a test page, then if you see something printed but not good qaulity, clean print heads again....if this doesn't work you can take a damp cloth and wet and wipe under the ink cartilige where the ink comes out but is dried and clogged up until you see a rainbow streak of red, blue and yellow, be carefully not to wet any other part of cartirige, you can use a moist q tip if you want.
Jun 28, 2010 | Lexmark Z715 InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer is running a white streak through the center of pages
1. Turn the power to the printer "off."
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
I changed all the cartridges and it still won't print in color- what now.
Are you sure you have the correct drivers installed for that exact model of printer? Check to make sure your OS recognizes the printer as having color capabilities. What happens when you print a test page?
Jul 02, 2009 | IBM Lexmark Z715 InkJet Printer
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
May 05, 2009 | Lexmark Z715 InkJet Printer
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
Lex-Z25 Blank Pages
need to install my Lexmark Z25 to my laptop.recently upgraded to windows XP
Jan 05, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Dell Photo 964 All-In-One InkJet Printer Logo
156 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
