Question about Kenmore Washing Machines
Kenmore washer agitator
I have a Kenmore washer model 110.27812692 and the top portion of the agitator is not working. Any suggestions? Thanks, Mike
  • mjmason357 Feb 08, 2009
    Thanks clarkco,
    I'd like to take the agitator apart and have a look see before I order the repair kit. Know how to take one apart? Aloha, Mike
  • 360 Answers
You need a agitator repair kit...about 20 bucks plus ship, not a difficult repair.
searspartsdirect.com is down for maint right now however, here is a link get one and a pic to see just what it looks like -->click here<--
Please take the time to give this a Fix Ya rating and as always thanks for using Fix Ya.
clarkco
Posted on Feb 08, 2009
Top portion agitator not working - Kenmore 110.27812692
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27812692
and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Apr 27, 2010 | Kenmore Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
The agitator (upper portion) will not spin. If I
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Mar 02, 2010 | Kenmore 22422 Top Load Washer
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore top load washer, The top part of
The top section of a two part agitator is designed to turn only one way. If the "agitator dogs" in it are worn, it wont agitate either way.
Also see the following on how to do it.
Oct 28, 2009 | Kenmore Washing Machines
The Top portion of the Agitator won't spin.
This is a very simple fix, that's inexpensive and requires no special tools. It sounds like you need to replace your agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The dogs are part of the agitator cam assembly under the auger (top portion). These little plastic pieces do wear out with age, causing the slippage you are talking about. Replacements are available at appliancepartspros.com for about $5. For a little bit more, you can purchase the entire cam replacement kit (which includes the dogs, cam and seals) for around $11 or $12. Use your model number to begin your search criteria and locate these parts under the "Agitator Parts" section.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Aug 19, 2009 | Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer agitator will not work.
is it a kenmore top load washer?and does it spin and drain?let me know more-mike
Mar 31, 2009 | Kenmore Washing Machines
Agitator slipping
is it a top load washer?if so there are 4 dog ears under the agitator cap that turn it ,you need to replace them($2 at your local appliance parts store-mike
Mar 19, 2009 | Kenmore Washing Machines
Washing Machines Logo
67 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
