Question about Pioneer DVL-919 DVD Player
LD Repeats itself every 15 seconds in play, DVD's play fine.
The LD play mode of Large Disks plays well for 15 - 20 seconds and the repeats the same signal. Sometimes it does this for 4 - 10 repeats and moves on for 40-60 seconds snd starts repeating again.
However, on DVD play, it works fine.
Any suggestions??? Thank you
  • fordhamroad Mar 25, 2009
    My DVL-919 repeats itself but it appears to be at random.
    It repeats about 10 to 30 seconds of a scene at any point during play back. So I would have to press the "FORWARD" button to go past that point to prevent this scene from repeating but then it will repeat at another random point during playback.
    Although I purchased my DVL-919 several years ago, I've really haven't used it much. I have another model Laser Disc player which is my work horse. I only use the DVL-919 for my special select movies which are very few. Could this be some type of "FIRMWARE" glitch? I took the cover off just to observe the operation. Should I lube the rail on which the laser pick-up head rides on? Perhaps the rails need lubrication? I see that the laser pick-up head travels alot from "SIDE A" to "SIDE B".
    Could the lack of lubrication on the rails be causing binding on the travel of the laser pick-up head?
    Need help A.S.A.P.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Posted on Mar 27, 2009
  • b175755 Nov 21, 2010
    Wow, thanks! My DVL-919 had the same problem. Lubricating it worked! Never would have figured that one out. Read about an 909 with the same problem also. Must be a weakness.
The music player in the samsung eternity repeats the same song over and over and doesn't play the next one in line. How do I get it to automatically play the next song on the playlist, like it was...
Try checking the playback options or options itself. Check if it is in REPEAT ONE mode. If it is, please change it to REPEAT ALL. And try to look for a CURVED ARROW PONTING TO THE LEFT WITH NUMBER ICON on your Player, if there is, REPEAT ONE MODE is activated.
Cheers!
May 31, 2011 | Samsung Eternity Cell Phone
Hdmi on tv loses signal
Try another HDMI input on your set and see what happens.
Jul 26, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
Having problem with a EMD 2203
sounds like the gear that work lazer is bad
Aug 12, 2009 | Emerson EWD2203 DVD Player/VCR
Two problems with my IBM thinkpad r31 (DVD player and Battery):
Your power plug inside the laptop on the motherboard is likely corroded around the positive terminal connected to the motherboard. Repair places will charge a few hundred dollars to fix this fairly simple problem not requiring any parts. Good luck. If you live in new zealand I can do it for you fairly cheap...
May 09, 2009 | IBM ThinkPad R31 2656 Notebook
Video fluctuations
Is this happening with commercial dvds or disks that you've burned? If it's happening with commercial disks, I would suggest trying the player on a different TV to see if the same thing happens. If it does, something is wrong with the player.
The warranty on the player is 90 days from the date of purchase. A receipt is required for warranty exchange.
Apr 11, 2009 | Coby DVD-224 DVD Player
When i am play a dvd it stops in the middle of the
Check that the disc is not scratched.
Check it with another DVD player.
Check if the problem repeats itself with a different disc.
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
Set the Delstar to Randomly play songs
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
Apr 29, 2008 | Delstar DS-3512 MP3 Player
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Panasonic dvd cv35 troubleshooting
hi first try unpluging the device for a half day and see if the problem repeats itself the manual recommend to ask for a technisihion to repair the unit before that try this: take a can of compressed air with a narrow hose open the discs drawer try to locate the laser eye with some light and clean it it should do the job good luck
Apr 03, 2006 | Panasonic DVD-CV35 Multi-disc DVD Player
Pioneer DVL-919 DVD Player Logo
214 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
