Question about Technics SL-1200 Turntable
Stopped working I have a 1200 sitting on a table ! yesterday it worked perfectly fine, the next day dead! seams its not getting any power anymore???? did not move it! any suggestions?
  • 1 more comment
  • misha539 Feb 08, 2009
    replacing the cable???
  • misha539 Feb 25, 2009
    Hi there I opened the back of the turntable and both fuses are still intact.
    You mentioned transformer I own a multimeter but need you to tell me which settings to set it to and what the figures are we are looking for.
    they are 2 fuses on that AC board but no red cables at all.
    please advise
  • Stephen Medley
    Stephen Medley May 11, 2010
    Have you tried another power receptacle? There is only a motor.
    President:
  • 624 Answers
If after trying another wall outlet, you still have no power to the turntable you may want to check inside the unit. Make sure the cord is not plugged into an outlet when you do this.
I am assuming that you have the Technics SL-1200 turntable.
Take the bottom off the turntable by removing the many screws in the bottom while the turntable is placed on a table upside down in front of you. After getting all those screws out, you will be able to just lift the bottom piece right up and off of the turntable. This turntable has several circuit boards in it. Look at the board that the A/C cord goes into and there should be a glass fuse on it. It is a small board with a couple of wires going to it and also a switch that comes from the blue, brown and red wires on that board. The glass fuse could be blown, if so replace it. If the fuse is good, you may need to check the switch or the power transformer. The transformer has 2 red wires going to it from that same board.
Let me know if you need to check the switch and transformer. If so, I will try to help you but you will need a multimeter and know how to use it.
Posted on Feb 08, 2009
    Sergeant:
  • 306 Answers
No! I meant trying another wall outlet. If you do not have a meter to check the power then try another plug. The motor will usually have some hum or noise if there is power to the motor. Steve
  • Stephen Medley
    Stephen Medley Feb 08, 2009
    Also moving the arm over the record will tell if it is a switch problem within the player mechanism -if it spins when you do that.
  • Stephen Medley
    I am an electrician/electronics tech also but you are my only eyes and ears, lol. Don't change any cables if you are not qualified to safely do so. Please post what you find/see/hear. Steve
Kleenmaid CH600CE ceramic cooktop stopped working
U sure power is getting to cooktop ?- chances of all burners not working and/or going bad at same time is ridiculous.
Get out your VOM and start tracing the voltages back to point of inception.
Sep 17, 2016 | Cooktops
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
My powerbass 150 amp was running perfectly one day, shut it off by the rockerswitch on the back to go to bed. Got up next morning, turned it on by the rockerswitch and no sound anymore, after about 5...
The problem with amps is they generate lots of heat when they are working and semi-conductors don't like heat, so overtime they fail. In your case either somekind of protection circuit has stopped an overload or one of the main semi-conductors that does the work has failed. It's off to the repair shop with it!
Aug 19, 2011 | Audio Players & Recorders
Phone says "out of range"
I'd try pulling the battery on the phone that is out of range and letting it sit for a couple of days. Then plug the battery back in and see if the phone activates. If nothing happens then try putting it back in the charger. My guess is if it's been sitting in the charger the whole time, the battery developed a memory and thinks it's dead.
Mar 11, 2009 | Uniden Cordless Phone
Cuisinart DCC-1200 won't turn on
Yep. Unplug for 20 minutes or longer officially. If it doesn't work, your serial number may still put you in warranty. They have a longer warranty period than anyone.
Jan 02, 2009 | Cuisinart DCC-1200 Coffee Maker
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Technics SL-1200 Turntable Logo
260 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
