Question about Garden
A kobelco acera sk200 trouble code is restricted air flow .
Im tryin to fix this trachoe for a friend even if you take the air filter out the computer keeps sayin that the air flow is restricted how do i fix it?
    Problem Solver:
  • 9 Answers
With the engine NOT RUNNING, remove the intake air hose from the engine and work your way to the air filter box to verify there is nothing in the intake airway path. The sensor for the air filter system works off of a vaccum, thats what makes the terminals connect. Unhook the wires from the sensor and check for continuity from the 2 terminals, if no continuity problem is in the wireing harness ( signal wire is going to ground ), if you have continuity, you have a stuck switch.
Posted on May 19, 2009
How to work on code p0101
Definition of Diagnostic Trouble Code P0101 Category: Powertrain Definition: Mass or Volume Air Flow "A" Circuit Range/PerformanceNote: This definition of P0101 is applied to all manufacturers
Jul 05, 2015 | Cars & Trucks
I have a 2002 chevy blazer it dies when i go to stop and has trouble picking up speed after pushing gas
Could have a vacuum leak , Is the check ENG. light on ? Could need spark plugs, plug wires ,distributor cap . The IAC motors ,idle air control motor passage could be plugged with carbon. Bad mass air flow sensor could do it. Check for critter nests , found that cars that sit for a while , squires and rodents like to make nests under the hood . I have found air boxes full of dog & cat food. They take insulation and make nests. Check the Air Cleaner Restriction Indicator
The air cleaner restriction indicator is located on the intake duct between the air cleaner assembly and the mass air flow (MAF) sensor.
If the area inside of the clear section is green, no air filter service is required. If the area inside the clear section is orange and Change Air Filter appears, replace the air filter.
Jan 05, 2015 | 2002 Chevrolet Blazer
1993 Kobelco SK 60 Acera had an ignition issue that was fixed but now the machine runs fine for about 30 minutes then bogs down like it is starving for fuel. Any suggestions for a fix?
It sounds like there is a venting problem with the fuel tank. These tanks have a vent check valve at the top of the tank that normally lets in air as the fuel is being used but in earth working machines this vent becomes blocked from dust and blocks off
Aug 01, 2014 | Cars & Trucks
Error code excavator kobelco sk200-8
Oct 18, 2013 | Toys
2000 nissan sentra 2.0 error codes p0101& p0102
P0102 - Mass Air Flow Sensor Circuit Malfunction
The mass air flownissan-maxima-maf-sensor.jpg or MAF sensor is placed in the intake air duct between the air filter and the engine intake manifold. The MAF sensor measures the amount of intake air flow. The MAF sensor converts the air flow measurement into a voltage or frequency signal, with the voltage or frequency changing proportionally to the amount of air flow. The air flow sensor signal is monitored by the engine computer (ECM). The engine computer (ECM) uses the mass air flow signal to know the engine load and to calculate the proper amount of fuel injected. If the signal from the mass air flow sensor is out of expected range, the ECM detects a fault and sets the code P0100. For example, the mass air flow sensor signal could be higher than expected when the engine is not running or lower than expected with the engine running. A car with the code P0100 may have some driveability issues, such as stalling, lack of power, surging, hesitation, etc. In some cars, the code P0100 can cause the fail-safe mode where the engine speed would be limited to 2,500 - 3,000 rpm.
If there are other trouble codes present, they might need to be looked at first. Checking the freeze frame may help, as it may contain some important information. The freeze frame is a snapshot of the engine parameters at the moment when the fault was detected. The freeze-frame may show whether the vehicle was running or stopped, whether the air-fuel ratio was lean or rich, was the engine was cold or warmed up at the time of the malfunction. Read more about the freeze frame.
Read more about mass air flow sensor.
What could cause the code P0100:
- faulty or contaminated mass air flow sensor
- open or short in the mass air flow sensor electrical circuit
- open or short in the sensor power or ground circuit
- other electrical problem with the MAF sensor wiring, (corroded wires, bent terminals, bad ground connection, burned fuse, etc.
- vacuum leaks
- restricted air flow at or before the air filter
- wrong air flow sensor installed
- problem with ECM
P0102 - Mass Air Flow Sensor Circuit Low
The mass air flow or MAF sensor measures the amount of air entering the engine. The engine computer (ECM) uses the mass air flow signal to calculate the amount of fuel injected (read more how the MAF sensor works below). The code P0102 is set when the signal from the mass air flow sensor is lower than expected. Often a car may exhibit some driveability symptoms, such as lack of power, surging, hesitation on acceleration, hard starting, pinging (detonation), or rough idle when started cold. Often the codes P0171 or P0174 could also be stored along with the code P0102, as the incorrect air flow signal can cause the engine to run lean. The codes P0171 and P0174 indicate a lean condition. Checking the freeze frame might help in the diagnostic process. The freeze frame is stored in the ECM along with the trouble code. The freeze frame contains some recorded parameters (e.g. vehicle speed, engine temperature, fuel trim) at the moment when the fault was detected. The freeze frame can also be accessed with a scan tool.
What could cause the code P0102
- faulty or contaminated mass airflow sensor
- debris blocking the air flow at the mass air flow sensor
- unmetered air leaking past the MAF sensor (vacuum leaks)
- PCV system vacuum leaks
- restricted or collapsed intake air duct
- dirty or restricted air filter
- restricted air screen before the air filter
- improper application of aftermarket components (e.g. cold intake, modified air filter, etc.)
- electrical problem with the MAF sensor wiring, connector, power supply or ground.
- problem with ECM
- in some cases other issues with the fuel injection system like a clogged catalytic converter or a faulty manifold absolute pressure sensor (MAP) can also cause the code P0102.
Solution for MAF repair
Oct 20, 2012 | 2006 Kia Sorento
Car is having trouble starting
If the check engine light is on you may want to have the computer checked for trouble codes first.
Sep 20, 2012 | 2002 Buick LeSabre
I have replaced the port seals, isolater bolts, cleaned the EGR ports, plugs and wires, and chanced the air filter. I was getting both 171 and 174 codes. Now after 60 miles or so, pulled the codes again...
P0171 is a lean fuel condition . The computer reflashed has nothing to do with it . Vacuum leak intake manifold probably . If both P0171 & P0174 were back could be fuel pump low flow or restricted fuel filter . or O2 sensor problem or mass airflow sensor. Suggest you take it to a qualified repair shop to have it diagnosed .
Ford 150 P0171 P0174 Trouble Codes vacuum leak water test
Diagnosing Faulty Mass Air Flow Sensor P0171 P0174 Lean Codes
Aug 10, 2017 | 2000 Ford Windstar
Want to know engine light p0102 code means
P0102 is the generic DTC (Data Trouble Code) for (Mass or Volume Air Flow Circuit Low Input), and it would most likely be a fault with the MAF (Mass Air Flow) sensor.
The MAF sensor could be dirty or faulty, and there might even be restricted air flow to the MAF sensor (like a plugged up air filter). Also be sure that there are no air or vacuum leaks in the air induction system especially between the MAF sensor and the throttle body and that the hose clamps on the air induction system are all tight.
Jun 08, 2010 | 2001 Chevrolet Venture
Kobelco sk200 engine dies when trying to boom in or swing
Could possibly be a fuel related problem. Check the fuel inlet to see if it is restricted in any way. Water in filters. Fuel pump outlet pressure.
Nov 19, 2009 | Amana - AMA656030 - 6" Dado Sets
I like to now how to fix the code 0446 on kia optima 2001 2.4l engine. thanks
P0446 - Vent Control of the Evap System. This Evaporative Emissions System is very complicated. These particular DTCs (Diagnostic Trouble Codes) can be caused by MORE than they tell you. Three MAJOR components in the system can cause this P0446. 1. Charcoal Canister, 2. Charcoal Canister Filter, 3. Canister Close Valve, 4. Fuel Tank Pressure Sensor, 5. Purge Control Solenoid Valve, 6, Wiring and/or connector/connections between them and the ECU. If you wish to trust the computer's diagnostics, then replace the canister close valve (after you have inspected the Evap Charcoal Canister's air filter and find no problems with restrictions of air flow). If the problem comes back, check the Purge Control Solenoid Valve and the operation of the Fuel Tank Pressure sensor - either one of those components, if malfunctioning, can cause a P0446.
Apr 19, 2009 | 2001 Kia Optima
Garden Logo
564 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
