Question about Philips 55PP9401 55" Rear Projection Television
Picture seems to be losing its sharpness and colors bleed
I have a philips 60" rear projection HDTV monitor. it seems to be losing its sharpness and color. I've tried adjusting everything but still does not help. I'd like to try and fix this problem before it gets worse. thanks.
  • Philips Master
  • 8,617 Answers
Most likely scenario is that the coolant in the CRTs need replacement very common problem with phillips magnavox TVs, The picture will get hard to focus and the color will lose its intensity. You can get a coolant replacement kit for phillips at the following link under the repair kit category. The kit contains all the coolant needed and a CD with step by step instructions on how to do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Feb 08, 2009
2 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: picture seems to be losing its sharpness and colors bleed
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
The screen seems to be pretty dark, like the color is off a bit. it's not as sharp as i remember it being
Chances are that you will need to change out the coolant fuild in Tubes Philips are well know for having Bad Coolant Fuild in the Green/Blue Tubes.You can remove the back and turn TV on Then Look down inside Tubes if picture is not Clear then coolant fuild is bad.
Mats Electronics has coolant fuild 1-800-628-1118
Jun 29, 2011 | Philips 60PP9202 60" Rear Projection...
The tv seems to be glowing, especially all the bright colors. Have adjusted brightness, sharpness, color and so forth and nothing seems to fix it. What can I do?
Your problem is the fluid in the 3 picture tubes needs to be replaced. All the older projection sets used this type of cooling for the tubes. After time and usage the fluid becomes contaminated and starts to turn brown and light cannot get through the crud and therefore you wind up with a dull picture. I recommend having a service company do this procedure. It is very detrimental to the printed circuit boards and components if you would spill and on them. Most shops charge around $250.00 to replace the fluid.
Jan 04, 2011 | Philips 60PP9202 60" Rear Projection...
Color issues
most probably your convergence circuit has gone bad.  could be as little as a burned resistor or two to the convergence i.c.'s being bad.  may be time for a tech
Jul 31, 2010 | Philips 60PP9202 60" Rear Projection...
What should my picture setting be Brightness Color Picture Sharpness and Tint
the better effectiveness the colour settting should be average that is 50%, the sharpness on 70%, brightness on 60%, and tint on 50%.
Hope this will help...
May 31, 2010 | Philips 51PP9910 51" Rear Projection HDTV
60pp9202 picture very dull not as bright when new
This occurs in projections set because they use ethylene glycol to keep the face of the tube cool. After time it becomes cloudy. A service company can replace it, normally costs around $300.00
May 06, 2009 | Philips 60PP9202 60" Rear Projection...
  • Screen looks 3D
Feb 22, 2009 | Philips 60PP9401 60" Rear Projection...
MY HDTV SHOWS A A SHADOW NEXT TO LETTER OR PICTURES
you need the phillips DPTV305 - DPTV345 convergence repair kit which is available at the following link which includes step by step instructions on how to do the repair yourself. Heres the link.
Jan 18, 2009 | Philips 60PP9202 60" Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Color Problems 60PP9352 60" Rear Projection
Check to make sure the green is lit up! You will need to remove back and look inside to tell.
Jan 06, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
282 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
