Question about Brother P-Touch 2420PC Label Printer
Brother P-touch 2420PC won't print
The power light is on, but won't flash, and I get an error message 'Communication error between PC and P-touch. Have tried using a different usb cable.
  • ravenburn Apr 25, 2009
    Yep, same problem. It had been working perfectly. I changed the USB cable, reinstalled the driver and even bought a new usb pci in case that was the problem. I somehow had success one day but it didn't work the next. Very annoying...
Aha! I got it :D.
Go to: http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faqp/000000/001400/000038/faqp001438_000.html?reg=eu〈=en&c=eu_ot∏=2420euk&page=FaqEndPage and download the driver removal tool, then reinstall. I had removed it manually and reinstalled but it obviously didn't delete the registry entries. It's working fine now. Good luck! Hope this helps you too.
Posted on Apr 25, 2009
How do I Fix a Unable to Initialize error message 51 on a Brother MFC 820CW
Error 51 relates to print head parking position.
It is blocked and carriage cannot be seated correctly.
Try to get carriage away from parking position by pulling power lead when head has moved away from parking position then slide it out the way and use a flash light to look at parking position.
look for paper debris or similar which might block it or upset a sensor.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
I get a message saying the printer cannot communicate with computer. Everything is connected properly. Also, the wifi light is flashing. Sometimes it prints, but it randomly cannot...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Unplug and re-plug the printer into the power source to reset it. Reboot your computer.
You may also refer to this article found in the Lexmark website: How to identify a Wireless Communication Problem and Resolution Tips.
Jul 13, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Not enough disk space to spool document error message when using Brother Ptouch QL-500. All other printers are working well.
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps.
Jun 06, 2011 | Brother P-Touch 2420PC Label Printer
P touch 2420pc I cant change lenght of tape. keeps defaulting to 100mm
Usually if you change the setting in the printer and save it, then it changes back to some other setting after printing, the setting is being overridden by the same setting in the printer driver. Make your change in the driver.
Hope that helps...
May 05, 2011 | Brother P-Touch 2420PC Label Printer
I have a P-touch 2420 PC that has been working fine. today the printing of labels is all mixed up. even the individual letters are corrupted
If restarting your computer does not solve the problem your driver probably got corrupted. In this case you should delete the printer (Start - Printers And Faxes,Right Click the printer, Choose Delete). Now you re-install the printer. Be sure to use the correct driver.
Feb 08, 2011 | Brother P-Touch 2420PC Label Printer
I have a P-touch QL-500 brother label printer. When I try to print my label I get error message Not egough disk space to spool document
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Jan 24, 2011 | Brother P-Touch 2420PC Label Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Brother P-Touch 2420PC Label Printer Logo
1,929 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
