Question about RCA RT2280 System
Buzzing sound through the speakers
When i turn on my stereo (rca rt2280) it has a low or sometimes high buzzing noise in the backround, it gets louder as you turn the stereo volume down usualy, it does the in all input areas.
    President:
  • 1,902 Answers
Sounds like you are getting interferance from something like a cordless phone, TV, Computer something like that.
Posted on Feb 08, 2009
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
Arcam AVR200. Buzzing sounds in all 5.1 speakers. Gets louder as volume is turned up. Tried all sorts of different things - different power source, 1 speaker, different modes.
I had the same problem. I was told by a sales guy at a high end audio store that I should try using a 3-Prong To 2-Prong Adapter. I went and bought one. I plugged it in and no more buzzing.
you can find them at HomeDepot, Lowes or dollor store.11_25_2012_6_28_23_pm.jpg
Jul 12, 2011 | Arcam AVR-200 Receiver
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Mar 19, 2011 | Teac MC-DX20B CD Shelf System
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Crysler lhs, static buzzing noise in speakers when accellarating?
This is usually indicative of a ground loop causing noise from the vehicle electrical system. Long story short your stereo isn't grounded well enough.
There are two possible solutions:
1. Ground all components to the same point. This will reduce the potential and should greatly reduce any noise.
2. If number 1 is not possible (and it often is not), use a "ground loop isolator", available at nearly all electronics stores, or car audio suppliers. This device prevents a direct electrical connection between the two sources and will usually fix the ground loop.
Jul 06, 2009 | Car Audio & Video
Annoying buzz coming out
i have a similar problem, and i've seen loads of stories about the same problem from these speakers, it's a shame because otherwise these speakers are pretty good :(
The speakers seem to pick up interference, especially when the volume is low, they also sometimes give out periodic buzzes, but this could be individual faults with equipment.
Jun 11, 2009 | Logitech X-240 Computer Speakers
The side back speakers wont work. i have everything plugged in and when i do the speaker test they dont make noise...
make shure you have the correct polarity ,black negative and red is positive ,also make shure you have enough of the end of speaker wire stripped , if that is all good then remove the speaker from your system and hook it up to a regular stereo so you can test the speaker , if the speaker still does not work then you have internal problems in that speaker , if the speaker does work then you have problems with your sorround channel , if both the rear channels are not working it is highly unlikely that both speakers are defective so you probably want to consult the manufacturers warranty and let them either replace the speaker or speakers or the unit that supplys the power to the speaker , hope this helps you and good luck, glenn
Mar 02, 2009 | RCA RT2280 System
Chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Jun 22, 2006 | RCA RT2280 System
RCA RT2280 System Logo
236 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
