Question about Janome Memory Craft 4000 Sewing Machine
MC 11000 janome stops reading presser foot "p"
I can be embroidering fine, finish one, change and then it won't sew anymore
no matter what I do.
no banging - no lifting - no jarring - just sewing.
won't read presser foot "p".
thank-you
    New Friend:
  • 186 Answers
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
Posted on Feb 08, 2009
Janome 11000 sewing machine will not recognize the p foot is attached
If the presser foot has an clear glass eye (sensor), check that it is not dirty, dusty, or marred (perhaps a fingerprint). Anything that interferes with the machine's ability to recognize an accessory will prevent its use.
Dec 29, 2016 | Janome Sewing Machines
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
How can I get my janome 11000 to work when embroidering? The bottom thread doesn't even show and top thread is always breaking.
The tension(s) may be too tight and could be threaded incorrectly. Start out with a brand new needle. Be sure to RAISE the presser foot when threading the upper thread. Consult the owner's manual to be sure it is threaded in the proper order. Test your stitch on a straight stitch and adjust it so both threads meet in the middle of the fabric. This setting works for straight stitch. However, usually the upper thread tension is loosened a bit for embroidery so the bottom thread will not show on the top of the fabric. Test it on some small embroidery patterns first until it's where you want it.
Mar 05, 2016 | Janome Sewing Machines
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
Janome 11000, upper thread becomes tight when presser foot is put down. When attempting to sew, the bobbin tangles and bobbin case is dislodged
Re-thread the machine (presser foot up), making sure the thread is going through the opening in the up-take lever.
Mar 23, 2010 | Sewing Machines
Is this machine a high or low shank? I'm trying to buy a 1/4" quilting foot or seam foot and not sure which foot to buy.
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
Nov 12, 2009 | Janome 8080 Computerized Sewing Machine
How to put on presser foot "p" to embroider
Not shure you can embroider on an MC4000, i think this is only a sewingmachine.
But to change presser fot:
If it a "snap on" foot, when foot lifted, press the "button" on the back of the needle bar (on the bottom) this would release the presser foot.
If is a large foot, you have to unscrew the screw on the left side of the needlebar, and change the whole foot.
Jun 21, 2007 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
1,368 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
