Question about Mitsubishi WS-55809 55" Rear Projection Television
Light powers on then shuts off
You can hear a click when it comes on and off. like a relay switch on a car . its actually a ws-55819
  • Mitsubishi Master
  • 5,138 Answers
Replace Both of your STKs,They are Big Black ICs Will have STK 392-110s or 120,150, Replace with STK392-180s If Different Number Use Same AS on ICS
Posted on Feb 08, 2009
What does a 2-3 dignostic code on a Mitsubishi 55819 mean?
2blink-then 3 blink---------deflection circuit problem
It is a little misleading but means something in Horizontal or high voltage circuit (covers a lot of area inside the set) is bad.
Going to need a service manual, etc to try to track it down.
Entire chassis for this set can be removed====called a light box.
May 28, 2012 | Mitsubishi WS-55819 55" Rear Projection...
WS 55819 Mitsubishi HDTV , the tv turned off itself. The power light on for couple of second then off again. What is wrong with the TV?
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
http://www.retrevo.com/support/Mitsubishi-WS-55819-TVs-manual/id/276bh851/t/2/
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55819.pdf
http://service-manual.eu/model.php?id=2703
Above, a service and repair manual, above that are two user manuals.
May 09, 2010 | Televison & Video
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Aug 10, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 HDTV won't power on
At the very least you are not getting any of the Standby power to the Microprocessor (5 vdc). I would concern myself with that area once you get the manual. In the mean time check all the fuses.
Dec 01, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55 in. medallion hd 1080
try to solder it first if dont work u can get the same part on yhe net
Oct 13, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsibushi WS-55819 power problems
Wade, My dad has this same set and had the same problem -- Sears came out and replaced the power switch.
Sep 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Aug 12, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
