I have just build my new system baseed on a Abit KR7A-Raid board.
After power up the system nothing hapened. No bbep out of the speaker, no
video signal, just nothing had hapened. The green and yelow LED just look
good and shine. HDD FD and CD also DVD start as well as all coolers (CPU and
Mainbord fan) just start but thats all.
Whats going wrong ??? Will apreciate any comments and suggestions !!!
Thats my system:
- Mainboard Abit KR7A-RAID
- AMD Athlon XP 2000+
- 512 MB DDRRAM
- Housing CALVIN 9401-4b1 with 350 W power supply
- Grafic ATI Excalibur Radeon 8500
- HDD WD 800BB 80 GB
- CDRW YAMAHA 2200E-B10
- DVD Asus E 616
- CPU Cooler Artic Cooling Super Silent 2500
- Sound card TerraTec sixPack 5.1+RTL
Posted Via Uncensored-News.Com - Still Only $9.95 - #
With NINE Servers In California And Texas - The Worlds Uncensored News Source
Rating: 0%, 0 votes
perfectly...
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
mother board, put in on a phone book or the box it came in in order to
insulate it from any metal. The main cause seems to be a metal post under
the mother board where there is not a screw hole. The post then touches the
bottom of the board and shorts it. The next most common cause seems to be
reseating the memory and try one chip at a time. Reseating the video card
is right up there as well. The reason we like you to set the board up
outside the case is to eliminate any shorting situations and give you a firm
platform to insert the memory. Make sure the video card back plate goes
over the edge of the box so it doesn't push the card up out of the slot.
Clear cmos before you turn on the power and don't forget to return the
jumper to the original position before you hit the power. Use the absolute
minimum amount of devices to start (video, memory, cpu&fan, and a keyboard)
You don't even have to have the floppy drive or hard drives attached.
Another std. one is check the power supply and make sure it is on 110 and
not 220.
Hank
Post a New problem for ASUS CPU COOLER | P5M2 RTL
Email this problem
