Question about Polaroid T831 Digital Camera
My lens is stuck!
My lens is stuck on my t831 polaroid camera and won't go back in.
  • hglenn Feb 12, 2009
    //////////my lens is stuck as well , I thought my camera was the only one with this problem. If any one figures out a way to fix it please let me know. h.glenn@rocketmail.com
  • Anonymous Apr 11, 2009
    same as above with my wife's T831, used to happen on her samsung too. Thank god for my DSLR - no such problems there...
  • 423 Answers
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Posted on Feb 23, 2009
3 Suggested Answers
  • 441 Answers
SOURCE: my polaroid t831 turns on
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Posted on Apr 10, 2011
  • 11967 Answers
SOURCE: zoom will not retract; camera turns on and right off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 08, 2010
My polaroid t831 turns on then immediatly turns off, and the lens are stuck they won't go back in
Good day,
Regards
15073327
Apr 02, 2011 | Polaroid T831 Digital Camera
It will not turn on and it flashes a orange light
This is most likely a power problem, but could also be a stuck lens. Here's a couple of website that explain what you can try to get it working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
A stuck camera lens can cause this problem, also, but it's usually a power problem. Make sure your battery is fully charged, and the battery and camera terminals are clean (clean with a qtip and at least 90% isopropyl alcohol).
Good luck, and hope this helps.
Oct 15, 2010 | Polaroid T831 Digital Camera
Plug in polaroid t831 to pc and pc doesn't recognise that it is there
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
May 20, 2010 | Polaroid T831 Digital Camera
When I zoom in, the camera shuts off
Stephan, I had the same problem as this user did, I tried to zoom and it would shut off, what I did was one of your options, zoom and as I did turn the lens, like help it zoom. Now it works, thank you so much for your help! :) I thought my camera was doomed forever!
Nov 14, 2009 | Polaroid T831 Digital Camera
I need to download my Polaroid t831 driver
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Oct 29, 2009 | Polaroid T831 Digital Camera
Need user manual for Polaroid t831 camera. Model: CTA-00831H
Please follow the below link to download the manual.
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/T831-_E
Sep 09, 2009 | Polaroid T831 Digital Camera
Polaroid t831
I purchased a battery charger for my Polaroid t831 camera at Radioshack.com. It is a universal li-ion battery charger runs about $39.99.
Feb 11, 2009 | Polaroid T831 Digital Camera
Polaroid T831 Digital Camera Logo
246 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
