Question about Panasonic DVD-CV50 Multi-disc DVD Player
DVD remote control doesn't work while LCD TV is on
I have a Panasonic DVD player (model # DVD-CV50) which I got 8 years ago. The remote control for the DVD player worked perfectly fine with my old television, which was a 20" CRT TV. The TV was on a wooden stand with wooden shelves. My TV broke and I upgraded to a 42" LCD TV. I bought a new TV stand too. The new TV stand that I bought is a metal TV stand with glass shelves. The remote control for the DVD player works perfectly fine when the LCD TV is off. You can turn on the DVD player, start, stop, pause, etc. a DVD that is in the player. When the LCD TV is turned on, the remote control for the DVD player will not function. The DVD player will continue to operate manually, put the remote control can't be used. Can anybody help me to be able to use the remote control for my DVD player while my LCD TV is on? Please let me know. Thank you!
  • 1 more comment
  • Neal Ostlund Mar 09, 2009
    The batteries were recently replaced in the remote control for the Panasonic DVD player. The remote control is the remote control that came with the DVD player. There is a number on the fron of the remote control. The number is RAK-DV965WK. I hope that this helps. Thank you!
  • Neal Ostlund Mar 10, 2009
    Results from Solution #1 were posted as a comment on March 9, 2009. Still having the problem. Please help! Thank you!
  • Neal Ostlund Mar 14, 2009
    Here are the resuslts of the solution provided by praky16:
    I turned on my tv first. I then removed all the batteries from the Panasonic DVD player remote control, pressed each button on the remote control twice, then reinserted the batteries in the remote control. I then tried to turn on the DVD player using the remote control and nothing happened. Since my remote control doesn't have a volume or TV/DVD button, I couldn't press the power, volume, and the TV/DVD buttons together. I checked the battery compartment of the remote contol and I couldn't find a small three position slide switch, so I couldn't slide it.
    I am still having my problem. Please help! Thank you!
  • Panasonic Master
  • 19,396 Answers
That is not a remote problem, that means that the TV is creating interference that prevents the IR sensor on the DVD from working correctly.
The IR circuit on the DVD is the sensor that detects the remote control signal.
The only thing you can do is moving the DVD unit apart from TV.
If that does not work , there is no way of using this two devices together, I have seen this problem once, and the only solution we could get was replacing the DVD unit.
Posted on Mar 15, 2009
    Genius:
  • 1,239 Answers
Hi friend
this problem can be solved by reseting or restore factory settings try it
1. Turn the PowerSpec LCD TV/Monitor OFF with the Power button on the top of the unit.
2. Press and hold the Channel + button, then press and release the Power button.
3. Your PowerSpec LCD TV/Monitor will now be returned to the factory default settings.
now check it,,,,,,,
thank u,,,rating will be apreciated
Posted on Mar 14, 2009
  • 2,984 Answers
Just a suggestion:
Have you called and tried to get the manufacturer to replace it? Explaining all the attempted fixes?
They may send you a new remote or request to have you mail your remote to them.
    Sergeant:
  • 300 Answers
There are known issues with LCD TV interfering with remote control signals. This frequently happens with repeaters especially, which are often placed close to the TV when the units are hidden somewhere in a cabinet or enclosure. The issue is that the TV is continually emitting infra red, especially at start up, basically "blinding" the IR sensor on your DVD player.
Is your DVD player close to the TV and/or is there a shelf of any description between them?
In any case, there should be a solution, just by changing the placement of your DVD player in relation to the TV, especially if there is some form of solid barrier, such as a shelf, to stop the IR from the TV reaching the DVD player.
click the link
http://www.avsforum.com/avs-vb/showthread.php?t=1041947
    Top Expert:
  • Panasonic Master
  • 77,202 Answers
Why don't u just buy one of the many excellent universal remote's for about $12-15, they operate multiple devices, TV, VCR, DVD etc.
Posted on Mar 10, 2009
  • 94 Answers
The problem is the new tv can cross scramble the signal for your dvd remote when the tv is on such the dvd player is older i would suggest programing your new tv remote to your dvd player or just up grad the dvd player which i cheap now days and you will get a better quality pic out of a new dvd player with the progressive scanning i hope this will help you
Posted on Mar 09, 2009
  • 3,037 Answers
Hi
Since your shelves are glass, the interference is happening for the signal to the dvd player. Try putting a few layers of paper or a cloth layer under the tv on the shelf that it is on to shield it from the player. If the remote starts working, just get a new stand without the glass shelves or place the dvd player farther away
Let me know how this works out for you
Benjamin
  • 744 Answers
Hi..i would tell now how to do a remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working.... However, the remote would still not control the base unit. And now u do the remote base code reset (push power, volume and TV/DVD buttons together) but if this doesnt help u means then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote slid the switch back and forth several times returning to the default number one setting where it was before. Do not change anything on the base unit ur remote will start working now when u on ur tv.....
thank u!!!
    Brigadier General:
  • 3,614 Answers
may i know exactly the model of the remote,
try to change battery on the unit
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Astar 27" TFT LCD TV, Model LTV-2701
go to www.vancebaldwin.com and enter your model number and purchase a factory replacement
Nov 25, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
I need a remote control for a mintek 32 inch flat panel tv with built in dvd.the remote control is a RC -600. where can I find one?
It's tough trying to find OEM (manufacturer's) remotes. You could purchase a universal remote and program it to your set. Mintek doesn't have many codes and I believe 259 should do it. Good luck :)
Aug 25, 2011 | Mintek LCD TV Progressive Scan DVD Player
Panasonic dvd player won't show video (or anything) on tv
On the tv r/control press the av button until you see the dvd you are playing.You would be better connecting the dvd with a scart lead.
Aug 26, 2009 | Panasonic DVD-S54K DVD Player
Remote doesn't work for DVD Recorder
It is now working. The DVD is below a Panasonic TV. We blocked the tv remote sensor and the DVD remote started working. We have unblocked the tv sensor and the dvd remote is still working. I'm not sure what was wrong or how exactly we fixed it.
Jan 28, 2009 | Televison & Video
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Jan 12, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Unable to tune in generic remote control
I have the code book for this remote.  I am having difficultly with my Sharp CD player.
Codes for panasonic tv 0011,0024,0032,0106,0118,0131,0139,0212,1083,1140
codes for pioneer dvd
5008
hoped this helped someone
Dec 29, 2007 | Universal Remote Control Remote Control
Panasonic DVD-CV50 Multi-disc DVD Player Logo
133 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
