Question about Acer Aspire One Netbook 8.9" Notebook
3rd time, Sorry on the Acer Aspire One Netbook
It powers down suddenly and without notice. I stays running for about 3 minutes or so and then it shuts down
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Check the other solutions I posted for you.
    President:
  • 1,902 Answers
I own this same computer. It is the mother board Acer is very good at making bad mother boards
Posted on Feb 08, 2009
Shuts down on its own when using netbook
Possible dead battery, bad a/c adapter or processor.
Apr 16, 2014 | Acer Aspire One D257-13473 Netbook
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
Acer aspire laptop suddenly shut off and cannot turn back on
try it without the battery on the laptop. if it boots and stays on, put the battery back on and see what happens. If the problem persists, replace the battery. Acer will replace it free if you are still in warranty
Aug 09, 2009 | Acer Aspire 2930-4661 Notebook
My acer aspire one zg5 wont turn on
I assume there is something wrong with power supply...Get an electric meter and test the adapter for dc output..I think the bit that connect to the laptop may be worn out and hence losing connection..Try to play with the adapter end when connecting to the laptop and hold on firmly on it and watched if any light comes on.If it stays for more than 2 sec the you know it is faulty..That is an alternate option is you don't have a meter..
Jun 12, 2009 | Acer Aspire 5100 Notebook
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
My netbook shut down without warning
GO INTO THE THE PROGRAM AND DELETE ALL PROGRAM THAT ARE BOUNDLED IN THE PACKAGE AND REMOVE THEM UNTIL YOU RESOLVE THE ISSUES. IT MAY BE TAKING MORE POWER OR JUICE TO RUN THE ONE PROGRAM FOR YOUR CPU TO HANDLE ALL THE WORK
DID YOU NOTICE A DROP IN THE SYSTEMS PERFORMANCE AFTER INSTALLING THIS PROGRAM.
ROD
Feb 11, 2009 | ASUS P5P800-VM Motherboard
Acer Aspire One Netbook will not stay running
Most likely it is overheating. The cpu has a thermal monitoring device implanted in it that when it gets too hot it turns off the system so that the cpu does not fry. You have to make sure the vents are unobstructed & that while in use the laptop is on a smooth surface. You can upgrade the fan if you wish or purchase a laptop cooling pad that sits underneath the unit while in use. Hope this helps & please remember to rate my solution. Thanks.
Feb 08, 2009 | Dell OptiPlex GX260 PC Desktop
Acer aspire 5610-4654 keeps shutting down
Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
Can you start the laptop again just after it shuts down itself??
Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire One shuts off
Mine did the same thing -- noticed the fan wasn't running at all during bootup when the shutdown problem was occurring. Tapping the bottom ofthe case near the fan got the fan running and it booted fine after that. It happened twice in about a year's time and both times this fix worked. I'll probably take it apart soon and clean out the fan.
Jan 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
141 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
