Question about HP Compaq Presario SR1610NX (ED865AA) PC Desktop
CD-R/DVD and CD/DVD-R Drives Conflict.
I have the DVD/CD-R drive as primary master.
And the CD/DVD-R drive as secondary master.
It's on cable select.
It shows up in bios. But not on windows.
I check my computer and they don't show, I check the device manager and I see a ''!'' mark next to them.
They were working fine
  • 741 Answers
The ! means there is a conflict of resources, such as two have the same IRQ number to have the same memory address. You can check this in Device Manager. Click on the top bar "resources by type" then look to see if your HDD is using the same IRQ or Memory addresses as any other device....
Don't forget to rate this solution with 3 stars.
Posted on Feb 08, 2009
  • Randall  Trahan
    Randall Trahan Feb 08, 2009
    Also a couple of things. Make sure it is on it's on controller. If they are both on cable select then the one closest to the controller is the master and the other in the middle is the slave. Older 40-pin IDE cables do not support cable select. They both have to be on cable select. If they are not being identified by windows then configure the one closes to controller as master with the jumper and other one as slave with the jumper. Good luck let me know how it turns out.
    President:
  • 1,179 Answers
Try setting the jumper on 1 to master & on the other to cable select. See if that fixes your problem. Hope this helps & please take a moment to rate my solution. Thanks.
I have the same problem
check ur all connections on motherboard..also try to change power supplier i.e. SMPS
Jul 31, 2009 | Dell Dimension 2350 PC Desktop
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
Ide channels not working right after updating dvdrw firmware Set on ide channels should be Primary ide Hard drive primary master. Primary secondary hard drive. Secondary master dvd (read only) Secondary...
usually when you update or re-flash the dvd rom.
it will state :- ensure that the drive to be flashed should be jumper set as master. if there were other drives connected to the same ide channel. this could have caused damage to the other drives connected. Or the IDE Channels themselves.
The only suggestion I have for you. is to remove all the drives. disconnect the power from the computer. and remove the cmos battery, for 10-15 seconds. resetting the computers bios back to defaults. then re-settup the drives ensuring that the jumpers are correct for each drive. i.e 1 slave and 1 master on each ide cable.
Mike @ Compurepair.
Mar 26, 2009 | ASUS A7V8X Motherboard
How set the hard drive and dvd-rom
first idea is to set the Hard drives on the primary controller on the same cable, having your hard drive with windows as the master and the other as slave ( do this with the jumpers).
Next put your cd\dvd drive on the other cable on the secondary ide (the name is usually IDE2).
turn on your PC and pres delete to go to the bios settings,
once there go to the basic cmos settings page, and make sure you see the settings there as you wanted,
Primary master first hard drive
Primary Slave second hard drive
Secondary Master your cd\dvd drive
helpful ? if not give me a reply for more help
Mar 23, 2009 | Computers & Internet
Dell2 2400 BIOS F2 reads backwords.
It sounds like you may have the IDE cables hooked up backwards on your motherboard.. The IDE cable slot on the motherboard labled IDE1 should be where your Hard drives are if you want them to read as primary. The Optical drives are usually on IDE2, designating them as secondary.
Let me know if you need more help.
Mar 12, 2009 | Dell Dimension 2400 PC Desktop
I have bought two hitachi 160 GB hard drives and need jumper setting explained please
The usual jumper settings for a hard drive are:
  • Cable Select
  • Primary
  • Secondary
Cable select means that the mainboard will choose whether to make the drive primary or secondary. Most mainboards today support cable select. And, most drives will have their jumpers already set to cable select. You can just have all your drives set to cable select, and the mainboard will take care of the rest.
“Primary” means first and most important. Think of the primary as the one that usually takes control of the cable and gets its way. The secondary is like a little brother who must usually wait.
You usually want your main hard drive set as primary, or set it as cable select and have the mainboard set it as primary
Sep 16, 2008 | Hitachi Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
Cd rom and dvd drives were not visible.
Hi purushoth,
So neither of the ROM drives are available, or just the one? Your jumper settings may or may not be correct; in some systems, even having the IDE cable placement and jumper settings correct may still leave errors such as this.
Basically if you dink around with the settings (for example just try changing the Slave and Master) it will work (provided there's nothing wrong with the drives or IDE cable). I'd also suggest setting both to Cable Select as some systems (such as Sony VAIOs) oftentimes will only allow optical drives to function with that setting.
Ben
Feb 25, 2008 | HP (344542-005) DVD Drive
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
HP Compaq Presario SR1610NX (ED865AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
