Question about Philips HTS3450 System
Sound i got a hts3450 at the good will :P but with now speakers at all , is there a hack out there to rewire the 5.1 sound to just using rca jack's? or to make a new pbc bord so i dont have to use the VGA port on the back of the unit ?
    Scholar:
  • 144 Answers
No, this is not possible because the sub is also amping and decoding the sound, so you need an additional surround amp and processor. Check on ebay if you can find some HTS3450 speakers, i know a lot the sets are damaged and than the speakers are worthless.
Posted on Apr 17, 2009
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
The sound in my player is very faint, you can hear it playing softly, but thats with the volume turned all the way up. i re-hooked all the cords & wires and still can't get that great sound back....
Have you been using the headphone jack a lot?
If so, the contacts may be bent and not turning the speakers back on as they should..
Put a headphone pug back into the jack to see if there is good volume there or not.
If not, Houston, you have a problem.
Do you have a Speaker Selector switch on that unit?
If so... turn it off and on a few times in case of a bad connection.
Are you sure that the speakers are connected to red and black and not to black and black by mistake?
try another speaker to see what happens.
Jun 01, 2011 | Philips HTS3450 System
Why? no sound from the speskers at all.
There are a few things that could cause no sound and although some are obvious I'll got through them all..
1) Sound is on Minimum
2) Sound is Muted
3) No Power to Subwoofer
4) Speakers connected Incorrectly or Faulty
5) No AUDIO IN connections to TV-IN or AUX-IN
6) Incorrect Input Source is Selected (See Below)
Connecting audio from TV
When connecting the audio output from your TV to this Home Theater Audio System, you will have the sound of the
TV output on all the speakers. It will enable you to enjoy the multi-channel surround sound capabilities.
Use an audio cable (red/white - not supplied) to connect the TV IN jacks on this DVD system to the AUDIO OUT
jacks on the TV. To listen to the sound, press TV on the remote control as the sound source that you want to play.
Connecting audio from an audio/video device
This DVD system provides analog and digital audio connection. You can connect the audio output from an
audio/video device (e.g. VCR, Cable/Satellite Box) to this Home Theater Audio System in order to enjoy the
Use an audio cable (red/white - not supplied) to connect the AUX IN jacks on this DVD system to the AUDIO OUT
jacks on the connected device. To listen to the sound, press AUX/DI to select "AUX" as the sound source that
you want to play.
Or
Use a coaxial cable (not supplied) to connect the DIGITAL IN jack on this DVD system to the DIGITAL OUT jack on
the connected device. To listen to the sound, press AUX/DI to select "DI" as the sound source that you want to play.
Please leave feedback
Cheers
Andy
Apr 27, 2011 | Philips HTS3450 System
I have a budda superdrive 30 II amp and have a setting question. I made a 2-12 cabinet to hook to this amp. Each speaker is 4 ohms. They are wired to their own output jack. My amp has 2 outputs for...
You best rewire the cabinet to put the two speakers in series. Wire one speaker plus to minus of the other and bring the other lead, one from each speaker to your jack on the cabinet. The amp output impedance is what is set on the switch... for two 8 ohm speakers you would use both jacks to the two speakers BUT ssince you have 4 ohm speakers the ONLY option is for two in series and set the switch to 8 ohms. The amp is ONLY 30 Watts so don't expect too much sound output... You should get a nice CLEAN sound at a reasonable level. If you drive the amp too hard it will clip and you will get garbage.
Apr 22, 2011 | Budda Superdrive 30 Series II Amp Combo
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Why is my dvr 6300 sound goes and comes
One mistake many peoples make when it come to surround sound is that they don't hook up the right pole from receiver to speakers. Every receiver is very sensitive when it come to connecting the speakers correctly. make sure their are some kind of marking on the wires letting you know that is the positive line and no marking would be negative. hooking the wrong pole can short circuit the unit or burn it out quickly or work poorly. check your speakers connection making sure it has a good connection. check your rca jacks making sure they are good rca jacks connect to and from your systems. First I would check the wires making sure speakers connected to the wright pole from and to receiver, second check all the jacks making sure they are all good. Bad or blown speakers will also cause the rattling noise. test each speaker by using one good out put channel and swapping each speaker making sure they are not blown this way you can eliminate the speakers are bad or good. If everything check out than your receiver is defective, actually local electronic repair shop can test the unit if its out of the warranty.
Aug 24, 2009 | Kenwood Audio Players & Recorders
Connection
Your TV should have an audio output which are red and white colored jacks, labeled audio out, on the back of your TV. There are also be the same inputs on the home theater system. You would have to buy an RCA cable which is inexpensive. You can then connect the TV from the audio out jack to the AUX 1 or 2 jack on the rear of your home theater system. Then select the AUX 1 or 2 input option (the one you hooked the cable into in the rear) on the home theater system, and you should be in business.
Feb 05, 2009 | Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
HELP: Onyo Remote Does Not Recognize Receiver when using Cable
Since you have the cable connected to the reciever thru the HDMI, you may have accidently changed the input source of the reciever from HDMI or digital to analog.
When you have the reciever set to listen to the cable, check the input mode and make sure it is set to use the HDMI or digital input and not the analog.
The rca jacks are analog, and they worked, so I think you have just solved your own problem without realizing it.
Let me know if this works and if so a good rating would be appreciated. Thanks and have a great day
Jun 16, 2008 | Audio Players & Recorders
Philips HTS3450 System Logo
168 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
