Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Netopia 2247nwg default password
I have lost my documentaion and can'f find the default user (admin?) and password . does anyone know???
  • Anonymous Feb 28, 2009
    klnyhjrythjthehye5yh rwgtrger
    President:
  • 1,902 Answers
Default password is PASSWORD
Posted on Feb 08, 2009
I purchased a Motorola Netopia 2247-62-10NA 4-Port Modem. I have followed the instructions and am unable to activate the internet. The instuctions ask for a user name and a password that is supplied by...
First make sure the dialling is done to the correct number - it will be listed in the contract papers.
Phone your ISP and request them to confirm you that those are indeed the correct username and password.
Sep 14, 2011 | Netopia 2247NWG-VGx Wireless Router...
Firewall set to high on my netopia 2247nwg roughter how do i change it
Try browsing to http://192.168.1.254, which is the default address of the router from the factory. If it's been changed you'll have to find the address of your computers 'default gateway' and use that instead.
Username is 'admin' and the default password is the serial number printed on the router itself.
Once into the router, you should be able to find the firewall settings and adjust them as necessary.
Good luck.
Mar 24, 2011 | Netopia 2247NWG-VGx Wireless Router...
How do i find my security key on my router?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 11, 2010 | Netopia 2247NWG-VGx Wireless Router...
How do i turn off the wireless on my netopia 2247nwg router
Type 192.168.1.254 Enter your password default Username-Admin Pass-Admin
Once in there find your wireless setting and turn it off. I personally do not have a netopia router but these are the usual steps, if you have any problems comment back and i will be glad to help.
Mar 20, 2010 | Netopia 2247NWG-VGx Wireless Router...
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
What is the default password to turn on wireless
Hello, dtpineapple1
Many times there is a sticker located on the device that requires the password. Look for a sticker that has a code written on it.
Good luck, jasahasch
Aug 13, 2009 | Netopia 2247NWG-VGx Wireless Router...
Where is the reset button and why does my router keep going off
you can find reset button in back side of it.
Press reset button for 10 seconds you can press it with niddle .
Then ci\onfigure it again
You can access your router with
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
thenh configure it as your isp settings.
Aug 01, 2009 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Unlock netopia 2247 router
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
May 06, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
2,014 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
