Question about CMB T43 750 Notebook
My laptop shut down on its own
It stay on for 5 to 10 minutes an then the laptop will shutdown automatically by itself. What do you think is the problem with my laptop?
    President:
  • 1,179 Answers
This usually signifies an overheating problem. You have a couple of choices. 1. Make sure your vents are clean & not obstructed, use on a flat surface. 2. Upgrade your cpu fan to one that has better cooling, or 3. Purchase a laptop cooling pad that sits under the laptop when in use. Hope this helps & please take a moment to rate this solution fixya. Thanks.
Posted on Feb 08, 2009
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
My aspire one d257 will shut down automotically afte a few minutes
Try running it on a hard flat surface and see if it runs better. The shutting down could be due to the machine overheating due to poor airflow. Try cleaning the air vents around the case, make sure they are not dusty.
Apr 09, 2012 | Acer Aspire One D257 Netbook
Long time shut down problem of laptop dell vostro 1015 with core 2duo
What is the exact problem.
A Does it turn off automatically after few minutes Or
B It fails to shut down when you choose to do so ??
If the system turn off automatically, try to clean the cooling vents and make sure that the system is not overheating
If the system fails to shutdown, test the system in safe mode. Restart and tap F8 repeatedly, select safe mode and press Enter. Once it start in safe mode, try to shutdown. If it able to shut down properly then the problem can be with your antivirus software
Sep 19, 2011 | Dell Vostro 1510 Laptop
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Override Dell Latitude D600 laptop automatically shutting down
yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
Turn of the display> change to four hours
Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
I hope this helps
Jan 10, 2009 | Dell Latitude D600 Notebook
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Computers & Internet Logo
73 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
