Question about Kenmore 44102 Front Load Washer
Washer will not do a spin cycle for rinse or end of cycle
Kenmore model 417 front loader will wash fine however when it comes to a spin cycle nothing happens, we can hear the machine still working, it drains water it just is not spinning
  • John Feb 08, 2009
    I will check, however if the belt is broken or streched would'nt that affect the washing cycle also?
  • John Feb 08, 2009
    President:
  • 1,902 Answers
You can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Posted on Feb 08, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 08, 2009
    No not at all, everything will work just fine, During the wash cycle it turns at a slower RPM so if the belt is stretched it will work ok on the slow turn but will slip during high RPM
5 Suggested Answers
SOURCE: kenmore washer 417 44252500 does not spin
replaice door swith
Posted on Feb 01, 2010
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
tragedy lok
  • 266 Answers
SOURCE: Kenmore 23812 top loader won't spin while draining
level sensor needs cleaned or replace
Posted on Jun 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore washer model 417 front loader won't wash
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer model 417
most time on kenmore washers any of them the lid switch goes bad you can replace it or bypass it,let me know-mike
Jun 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
My 4 yr old kenmore(G.E.made) front loader will not spin
you may need a new control panel and timer..not hard to do, but you'll need the serial number to get parts online.
Mar 09, 2008 | Kenmore 43042 Front Load Washer
Kenmore 44102 Front Load Washer Logo
571 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
