I have A desk top computer the Case is a tsunami Dream with a 430W power suppy the Motherboard is A ASUS P5B-E an intel CPU I recently was away from Home for 9 days when I left the computer was working Normally When I returned it Would Not Power on at allthe power supply apears dead no sound or led activity with the Mobo nothing
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of things that you could try:
  • verify that the power source is active. check the breakers, try another electrical device on the outlet, try the computer using another outlet/power source;
  • some power supply have a master on/off at the rear, pls check;
  • with a voltmeter (DVM/VOM), check for the absence or presence of voltages from the power supply;
  • alternately, remove the big connector from the power supply to the mother board, jump the green wire to any of the black wires. The fan of the PSU should turn. If not, it is a defective power supply; if yes, then it would be a motherboard /devices problem. try unplugging everything except the motherboard and try again.
Good luck and thank you for using FixYa.
Posted on Feb 08, 2009
  • 3,940 Answers
First thing I'd try is check and see if the power supply has a reset switch (Some have circuit breakers) and see if it powers on. (Some reset just by removing the power plug, then press and hold the power button for 10 seconds, then wait 3 minutes of the reset, then plug in power. If still no power try an different power supply.
    President:
  • 1,902 Answers
You have a dead power supply. One big test you can do to test for sure is take out the cable big cable that runs to the motherboard. Take a paperclip and make a U shape. Stick one end in the Green wire and the other in the red. If the fan turns on then the problem is not the power supply. If it does not turn on then the power supply needs to be replaced.
Bios problem what are new drivers bios
P5B-E Plus Uses 100% All High-quality Conductive Polymer Capacitors! - Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® P965/ ICH8R
- Dual-channel DDR2 800/667/533
- Fanless Design - Stack Cool 2
- PCI-E Gb LAN/ 8-ch HD Audio
- AI NOS™ / AI Gear / AI Nap
- SATA on the Go/ 1394/ Noise Filter
  • Another option is through the Internet. Launch the utility:
Start > Programs > Asus > ASUSUpdate
Follow the directions.
There is also ASUS EZ Flash.
Make sure that you do have a copy of your current or original BIOS, if you have the CD that came with the MoBo then you are golden.
Sep 20, 2011 | ASUS P5B-E Motherboard
My asus p5B motherboard doesn't want to install audio drivers and networkdriver
check for the right driver which comes with your computer cpu.
Apr 01, 2010 | ASUS P5B-VM DO Motherboard
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Computer won't resume after standby (os: vista)
Make sure all Vista updates have been installed, and check the ASUS website for any bios updates. I believe that motherboard had a known issue with stand bye.
Oct 18, 2009 | ASUS P5B Deluxe Motherboard
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
Asus p5b-vm se power problem
i had this problem before also...how old is your power supply?
Dec 08, 2008 | Computers & Internet
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
