Question about Craftsman 4" Drill Press Vise, Side - Plate Angle
Replace drill chuck on 23 year old Craftsman 8" drill press
I am tring to replace the 3/8" drill chuck with a 1/2" chuck on my Crtaftsman 8" drill press model no. 113.213722C. I do not know if it has a morse taper or is threaded on. Can anyone help me with this.
Scott
  • 2 more comments
  • sbradshaw640 Feb 08, 2009
    I have tried hitting it gently, then hard. I have tried driving a wedge in and it will not move. I suppose it is possible that it is seized in place from so long not coming apart. I do not know what to try next.
  • sbradshaw640 Feb 09, 2009
    I will give that a try, thank you.
    I started looking at drill chucks and realized some have retaining screws, when I checked, I had such a screw. I was able to remove the chuck with lite tapping once I had removed the retaining screw. Thank you for your help.
  • Anonymous Mar 29, 2014
    how do i change spindles ? threaded or morse taper ?
  • 10,865 Answers
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
  • Joe Hogan Feb 09, 2009
    The next thing I would do is get a can of WD40 and spray it on top of the chuck. Let it sit over night. Sometimes a layer of rust forms and ats likt glue. The WD 40 will make its way in there and dissolve the rust.
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    Drill will not rotate
    Did you have to set the chuck into the spindle, or when you got the press, was the chuck already attached to the spindle? With the drill press I got (different brand), I had to set the chuck in the spindle and I put pressure on the chuck to set it in by placing a bit in the chuck and drilling in a piece of wood, which placed pressure on the chuck. If that's not the issue, check to see that the pulleys are turning ( flip the top open). Also check the tension of the pulleys (machine OFF) If there is nothing apparent or obviuosly not working, and if the press is new, yes, I would return it.
    Nov 09, 2013 | Craftsman 23 hp 10" Drill Press with Laser...
    Require a 10mm and a 13mm Male-fitting Keyless Chucks
    I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
    Apr 04, 2017 | Drills
    Keyless drill has locked in a closed position with the drill bit
    I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
    Jun 04, 2010 | Craftsman 3/8" Corded Drill
    The chuck on my craftsman 8" drill press wobbles. How can I stop it from wobbling?? Can I get a manual for my drill. thanks. billybee3@yahoo.com
    There are a couple of different ways that drill chucks are attached on smaller tools. You didn't specify the model, so I can't help much. But here is a link to where you can usually find manuals for Craftsman. If the press is not too old, you will probably be able to find the manual here.
    http://www.searspartsdirect.com/partsdirect/index.action
    Feb 25, 2010 | Craftsman Drills
    3/8 Drill Driver, chuck replacement.
    hi friend,
    Step 1. Determine what kind of replacement drill chuck you want - a keyed chuck or key less chuck. Over the years, key less chucks have been widely used for handheld power tool drills, due to their improving grip torque and convenience.
    Step 2. If you prefer replacement key less chucks, then you have to know what type of key less chuck you will need - a single sleeve key less chuck or a double-sleeve chuck. You can simply determine it by checking your current chuck. If your current chuck is a keyed chuck or a double sleeve chuck, then you will need a replacement double-sleeve key less chuck. On the other hand, if your current chuck is a single sleeve chuck, then you should get a replacement single sleeve chuck.
    Step 3. Confirm the threaded mount size (spindle size) on the chuck. 3/8"-24 threaded mount for 3/8" capacity drill chucks and 1/2"-20 threaded mount for 1/2" capacity drill chucks, but there are some exceptions where just the opposite may occur. To be safe, always check the threaded mount before you buy replacement drill chucks.
    hope this helps u
    please rate me.........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
    Craftsman 10" bench drill press chuck wobbles
    If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
    Oct 07, 2009 | Craftsman Drills
    Remove and replace the chuck
    Most drill press chucks are held on with a screw. Open the chuck all the way. Look inside the chuck, there should be a screw in the bottom. Some are left hand threads, some are not. Good Luck
    May 28, 2009 | Drills
    Porter cable 884 cordless drill
    Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
    Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
    Craftsman 4" Drill Press Vise, Side - Plate Angle Logo
    2,082 people viewed this question
    Top Craftsman Drills Experts
    Tim Venetis
    Tom Chichester
    Are you a Craftsman Drill Expert? Answer questions, earn points and help others
