Question about IBM Wheelwriter 30 Typewriter
Ribbon replace on ibm selectra 2
How do you replace type writer ribbon on a ibm selectra 2
    Scholar:
  • 75 Answers
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Posted on Feb 08, 2009
Typewriter repair manual
I just replaced a ribbon in a 3500 IBM wheelrider ribbon with the following product which is supposed to be combatible.
DataProducts Compatible Typewriter Ribbon
Dataproducts Lift Offf Tape Catridge
I had no problem istalling the tapers, forwarded the ribbon as instructed, but when I type no tryping appears on my paper.
Aug 22, 2014 | IBM Typewriter Wheelwriter III 3 with 2...
Dvd writer will not read any disc can i replace the internal cd/dvd writer with any other
Hi:
Yes, you can replace your DVD writer with any other model, but there are 2 types, SATA and IDE.
The IDE drives connect with a wide , flat ribbon connector, and the newer, SATA drives take a smaller cable.
They are easy to swap out, and are basically plug and play!
Oct 24, 2009 | Acer Computers & Internet
HAVING TROUBLE PROPERLY CHANGING A CORRECTABLE RIBBON IN AN IBM SELECTRA 111 TYPEWRITER
Go to lexmark.com , click yuor way to publications there you will find an operators manual. The pictures and descriptions are better than mine. (Be sure you have the right ribbon Selectric III takes two different ribbons)
DickyO
Sep 23, 2009 | IBM Office Equipment & Supplies
Wheel writer II will not print - replaced with new ribbon
There's a small cap on the solenoid that pushes the hammer, this cap wears out and the solenoid cannot push anymore. Cheap part, always wears out, new ones are teflon and last lots longer.
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
DickyO
May 11, 2009 | IBM Office Equipment & Supplies
IBM Wheel Writer 6 font help
Hi:
There is no manual way to change the pitch on any IBM Wheelwriter. If you want a different pitch you need to change the printwheel.
Andrew
May 08, 2009 | Office Equipment & Supplies
Ibm Weel Writer 5
Check to see if the ribbon is lifting up, if not there is a black gear on the right side of the printer wiggle it back and forth until it will move. If it is lifting put a multi part form a nd see if it prints on the copies if not the plastic on the print solinoid is probably broken they are available but a bit trigky to install.
DickyO
Dec 10, 2008 | Office Equipment & Supplies
IBM Selectra III typewriter
There are two different ribbons for selectric III T/W's. One has the ribbon guides as part of the cassette the other the guides are part of the machine.
Be sure the ribbon and L/Oare installed properly and the ribbon is winding on the take up spool properly (counter clock wise) and if the guides are in the machine id to the left if thr white slacker finger just L. of the ribbon also be sure the L/O tape is behind the black seperation finger and the ribbon is in front of it (just to the rt. of the opening in the plastic card holder).
DickyO
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 30 Typewriter Logo
225 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
