Question about Texas Instruments TI-30XA Calculator
Dividing by a negative exponent
How would you do this problem on this calculator?  I can't seem to figure out how to put in the second half since it has a negative exponent.   Do I used parenthesis??
(2x3^2) divided by (2x3^-2)
(2x3^2) divided by (2x3^(-2))
just make sure to use double parenthesis around the negative exponent so that you get the right answer
Posted on Feb 08, 2009
How are numbers in scientific notation entered in Aurora SC150X calculator
Look for a key that is marked EE, or Exp, or x10^x. To enter a number in scientific notation, you enter the decimal part, then press the Enter Exponent key, followed by the exponent. If exponent is negative, you precede it with a press of the change sign key (-).
Once a number is entered there is no special treatment: multiply it divide, or add it.
Mar 16, 2012 | Aurora Electronics SC150X Scientific...
How does one enter a number in scientific notation in SC150X calculator
I am trying to divide a power of 10 by and another number to a neg power of 10
For integer powers of 10 you can use the EE shortcut. [2nd][,] displays E.
For non-integer values of the exponent (such as -5.34) you must use the key sequence [2nd][LOG] (10^x) then enter your negative non-integer exponent.
Jan 16, 2012 | Texas Instruments TI-84 Plus Silver...
How to enter exponents
If you mean an exponent of ten, use the EE function (the shifted function of the "," key, located just above the "7" key. For example, to enter 1.2 times ten to the negative 3, press 1 . 2 2ND [EE] (-) 3
To raise a number to an exponent, use the ^ key located just above the divide key. For example, to calculate 3 raised to the 4th, press 3 ^ 4 ENTER
Sep 26, 2011 | Texas Instruments TI-83 Plus Calculator
How do i type a negative exponent into the calculator? i.e. 4 to the negative second power.
4 ^ (-) 2
The ^ key is just above the divide key, the (-) key is just to the right of the decimal point key.
Aug 21, 2011 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus Silver Edition. When dividing negative powers of ten by other negative powers of 10 the calculator it just adds the the negative powers together. How do i fix this? An example: 5*10^-10 /...
To enter an exponent, positive or negative, use the EE (Enter Exponent) key (the shifted function of the , key just above the 7 key). Do 5 2ND [EE] (-) 1 0 / 5 2ND [EE] (-) 1 0 ENTER and you'll see 1.
What I think you're doing (I can't be sure without seeing your keystrokes) is calculating
5*10^-10/5*10^-10 which is interpreted as (5*10^-10/5)*10^-10, which indeed is 10^-20.
Oct 16, 2010 | Texas Instruments TI-84 Plus Silver...
Where's the EXP button on TI-30XB? i need to answer a problem just like this : -log2.5(EXP)^-4
To raise e to the xth power, use e^x, which is the second function of the LN key to the left of the 4 key.
To enter a decimal exponent, use EE, which is the second function of the , key above the 7 key.
To raise a value to another value, use the ^ key, above the divide key.
Also, don't forget to use (-) instead of - when entering a negative exponent (or any other negative value).
Sep 29, 2010 | Texas Instruments TI-84 Plus Calculator
How do i divide by powers of 10 in my TI-30XA calculator?
The same way you would divide by any other number. Just use the EE key (just above the 7) to enter the exponent. If the exponent is negative, use the +<>- key (just to the left of the =) to enter the negative sign.
Aug 30, 2010 | Texas Instruments TI-30XA Calculator
Negative exponents? .825/(10^(-3)) ? Not sure how to get it to do the negative exponent.
You entered it correctly. Although you can leave out the parentheses if you want. The calculator will do exponents before it does multiplication or division just like it does multiplication and division before it does addition and subtraction. It has a built in order for hierarchy of operations. You only need to use parentheses if you want to do something that is different from this order. FYI, dividing by a negative exponent is the same as multiplying by a positive exponent. You could enter it in either way. .825/10^-3 = .825*10^3 = 825. I hope this helps you out.
Dec 02, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
368 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
