Question about Sony RDR-VX555
VHS to DVD dubbing
Tried dubbing from a VHS to DVD using the push button on the unit, also went thru the remote. Neither works. When I push the button to start the screen turns gray momentarily then nothing.I cannot record from VHS to DVD. I can record fine from miniDV to DVD. I've tried both the "one touch" directions and the Menu directions to "simple dubbing" and nothing happens.
I was able to get one successful recording of ten minutes from VHS to DVD but with literally the exact same actions I not get no result.
I have been trying this for many weeks with different VHSs. I thought the copy protect area on the VHS had something to do with it but covered or uncovered, still no result. PLEASE HELP!
  • 9 more comments
  • adrianne66 Feb 08, 2009
    The disc should not be finalized because I am trying to record on it.
    I'm trying to record VHS to DVD using either the "one touch" method or the menu "simple dubbing" method. No result from either after following exact directions repeatedly. Please Help.
    Using Sony DVD-R discs. No other problems with these discs. Not trying to finalize yet, trying to copy several 10 minute segments from VHS to DVD using either the "one touch" method or the menu "simple dubbing" method. Neither works.
    I've been using Sony DVD-R discs for many months with no problems on this machine while recording miniDV to DVD.
    My problem has to do with this machine, not the brand of disc. I was able to get one 10 minute segment from VHS to DVD but not any more than that. Same exact instructions.
    Again, please read past the first section, because I'm not having a disc finalize problem, my question was lumped onto someone elses problem.
    My problem is taht I cannot record VHS to DVD using this machine. The "one touch" options and the "simple dubbing" options yield no result. I have been able to use the Sony DVD-Rs successfully with this machine to record miniDVs to DVDs so its not the discs.
    Please help.
    It's the same machine. It is supposed to work this way. There is no putting anything in between the input and the output because it is the same machine.
    I did it successfully for one 10 minute segment and now cannot get anywhere with this. Please read entire post! Thank you!
    Thank you - I've gone through the manual and the trouble shooting tips don't apply to this problem
    Hi thanks, not copying movies. Copying research VHS tapes that are not copy protected.
    Reset machine by unplugging for several minutes. Retried. No result.
    Again, using research VHS tapes with no copyrighting feature, trying to copy 10 minute segments to DVD using either the "one touch" option or the "simple dubbing" option. No result for either.
    I was able to do one ten minute segment (VHS to DVD), but cannot get anything else out of it since.
    Am able to use same discs and machine to copy MiniDVs to DVD without problems.
    Please help!!
    Thanks, but DVD is not finalized. I am trying to add to that particular disc, but I have also tried new discs and new VHS tapes with no result. The process is not working.
    Disc not finalized.
    Please help, read entire post. Solutions so far have been off the mark a bit. Would appreciate fresh eyes. Thanks!
    Master:
  • 416 Answers
You need to try to copy just some homevideo videotapes not movies. All them are copyprotected. Recording stops then copyguard is detected. It should be noted in the manual for this unit at page 47.
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/RDRVX555.pdf
Good Luck
Posted on Feb 08, 2009
  • 15,935 Answers
YOUR OWNERS MANUAL
Please follow the troubleshooting steps found on page 105 of the user manual.
Additionally, be sure all cables are hooked up properly (page 12)
Thank you for using FixYa - a FixYa rating is appreciated!!
  • blueextc3221
    blueextc3221 Feb 13, 2009
    Thanks for using FixYa. Your Rating of my solution to your problem was THANKS FOR TRYING. I would appreciate a re-evaluation of your rating - as the answer I gave was correct. There are not many experts that provide answers to FREE questions beacuse anything under HELPFUL reduces their overall rating percentage.
    The description FixYa uses for the rating system is misleading - a THANKS FOR TRYING means the answer was not helpful in solving your problem.
    We are working toward a better rating description to help alleviate the bad ratings.
    I took the time and answered your question to the best of my ability and request a change to at least HELPFUL.
    Thank you.
  • Sony Master
  • 1,800 Answers
There are a few methods to convert VHS to DVD:
- Capture the VHS video to a computer video editing program using an analog-to-DV converter (which includes many DV/Digital8 camcorders as well as standalone analog-to-DV converters), encode it to MPEG-2 and author a DVD, This is the most time-consuming method but it gives you the flexibility to edit the video as much as you want, adding transitions, special effects, music, etc. But, between the capture time, the editing time and the often considerable time it takes for software encoding to MPEG-2, this can result in several hours of work for your computer - and you - for each hour of video.
- Capture the video to the computer as MPEG-2 using hardware capture devices that convert the VHS to MPEG-2 as they capture and then author and burn a DVD. A one-hour video is captured and compressed to MPEG-2 in one hour, but you are generally limited to doing "cuts-only" editing of the MPEG-2 files. However, if your original tape doesn't need editing this is a fast way to convert VHS to DVD, but still have the flexibility to create custom DVD menus. Many of the inexpensive hardware analog-to-MPEG boxes can deliver very good quality, in part because the analog source video does not have to be converted to DV before being encoded to MPEG. Converting VHS to DV can add artifacts that make it harder to get good MPEG compression.
- Connect your VHS VCR or camcorder to a standalone DVD recorder that works much like a VCR. This VHS to DVD recorder basically gives you a DVD copy of your tape in real time. You don't have a lot of flexibility as far as menus, buttons and chapter settings, but it's the fastest and easiest way to convert VHS to DVD. If you get a "DVD VCR" with Firewire connections you can plug a DV/Digital8/DVCAM camcorder or VCR into it and transfer the tapes to DVD at even higher quality than by using the analog connections.
No matter which method you use, you need to ensure that the analog video has the highest quality possible: flaws in the original video may be greatly magnified when you encode it to MPEG-2 and convert it to DVD.
  • 129 Answers
Welcome to Fixya !
When you start recording Video onto DVD, It gets split into 10-15 mins long Chapters. I am guessing that your DVDs are getting finalised after the creation of the first Chapter. So it is not allowing any more recording on the disc. You may need to check the status of the DVD and the Chapter setup as explained in the page 49 of the manual -> http://www.docs.sony.com/release/RDRVX555.pdf
  • 744 Answers
Hi.. You need the device some times called Video Enhancer (SIMA-1, 2, or -200) to be connected between your VHS output and your DVD Recoredr Input. That would remove the VHS protection and prevented passing on through your DVD Recorder.
thank u
  • 1 more comment
  • Prakash Ram
    Prakash Ram Feb 08, 2009
    try out this link
    http://us.lge.com/download/product/file/...
  • Prakash Ram
     Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
  • Prakash Ram
    HI.... there are machines made for just this purpose. If you have a lot of VHS tapes to transfer to DVD, or you don't mind buying some extra hardware, purchasing an external device might be the way to go. For $100-$150 you can get a decent DVD burner that will hook right up to your VCR and create DVDs from your VHS tapes in no time.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For a newly recorded disc to be playable in another/external player other than the device that recorded it, said disc must be "finalized", that is the recorder must be instructed that no more files would be added and therefore the recording session must be closed.
Said feature/option would be among the MENU/Settings of the recorder.
Would appreciate updates. Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 08, 2009
    Appreciate your update/clarification. Let's start again and to your
    concern then not being the same problem, ideas that you could try:
    • use other brand of discs;
    • use only -R.
    Pls give the above a try and update.
  • Louie  Role
    See if there is a reset option, if not unplug the unit for an extended period of time. The unit should revert back to factory defaults.
    President:
  • 2,110 Answers
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
    Brigadier General:
  • 3,614 Answers
make sure that the disc was finalised. or you can try recording on a different disc
let me know
Need manual for toshiba D-vr 610 recorder
For VHS -> DVD dubbing, make sure that you put in a compatible writable DVD with enough space for the video. For dubbing a DVD to VHS, make sure that you have a VHS tape with the erase protection tab on the tape. Insert the blank media in the correct side and the media that you want to record in the other. Press Setup on the remote, then select the General Settings menu. Then select Recording and finally Dubbing. (Use the up/down arrows to navigate the menus and press Enter to select an option.) Select the type of dubbing that you want to do. Press Setup to exit. Then press the DVD or VCR button (with the item to record) and press play and pause when you reach the point that you want to start the recording. Then press the other device button and press the Dubbing button (on the remote or the unit). Press Stop when done recording the selection.
Note: copy-protected videos can't be dubbed.
Crutchfield and Toshiba both have the manual for the DVR-610 . Crutchfield has the manual here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/052/052DVR610.PDF . See page 49 for a set of screen captures of the steps for duplicating a video.
I hope this helps.
Jan 20, 2012 | Televison & Video
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Copy VHS INTO DVD
1. Set up with a new blank DVD.
2. Insert VHS and adjust to the beginning of
your recording.
3. Use the DUBBING button on your remote: you can adjust video quality (2 hours or 4 hours play) at this point.
4. RTFM for use of the PAUSE and DUBBING buttons to skip over commercials etc.
Feb 24, 2010 | Zenith XBR716
Instructions on how to burn from my insignia DVD to VHS
my Insignia is a different model (NS-drVCR) but I always use the "DUBBING" button on the remote (which is basically the tech-term for a Recording-Transfer). The screen-dialog then shows VHS Dubbing to DVD with quality options to choose. I'm not as familiar with going the other way (from DVD to VHS) but I know that mine can since I've done it once with a similar method, starting with the DUB-button.
Jan 11, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Dub vhs to dvd
Make sure that your system is on VHS before you press the dub button. you should then get a box that asks you do you want to record from VHS to DVD and it asks you to confirm this. you press the left arrow button so that the yes box is highlighted and then press enter and your dubbing should begin.
Aug 28, 2009 | Broksonic DRVCR900 DVD Recorder/VCR
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do we dub VHS to DVD without remote?
Fisrt, is it set up already to dub. It willnoe finallize if not. If so then just put a blank dvd in, push dubbing, insert tape, check source to make sure it is going to dvd then push dubbing again
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not copy vhs to dvd
I had the same problem. What I had to do was press the 'dubbing' button on the remote while in VCR mode.
Dec 27, 2008 | Televison & Video
Vcr - dvd player problems
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
Apr 06, 2008 | Samsung DVD-VR325 DVD Recorder/VCR
VHS to DVD dubbing
Press the 'DVD' button then 'Input' button at the top of the remote until 'Line1' or 'Line2' input is selected. I messed with this for quite a while until I finally looked at Sony's web site which states this.
Nov 22, 2007 | Sony RDR-VX555
Open Questions:
See all Sony RDR-VX555 Questions
Sony RDR-VX555 Logo
479 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
